Old 07-03-2011, 09:43 PM   #1
Hazieview
Building Dreams out of Dimes!
Will thus battery cable kit work with 2 optima batteries?
Hey guys I'm attempting to mount 2 optima batteries under the bed of my truck. I took a few measurements and I think this kit will work. I will be wiring the batteries in series with a disconnect on the secondary battery. That way I can run my stereo at the lake while truck is off without draining my primary battery.
http://m.summitracing.com/parts/PRF-40100
What do u think?
1981 Chevy short/wide.
SB400 350th
Hazieview is offline   Reply With Quote
Old 07-04-2011, 03:16 AM   #2
juiceman650
juiceman650's Avatar
Re: Will thus battery cable kit work with 2 optima batteries?
So you're gonna have a total of 2 batteries for the truck, which will both be under the bed correct?
juiceman650 is offline   Reply With Quote
Old 07-04-2011, 04:05 AM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Are you sure about wiring in series? Wouldn't parallel and cut offs work?
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 07-04-2011, 06:31 AM   #4
85sierraclassic
85sierraclassic's Avatar
series will make it 24 volts wont it?
85 GMC sierra classic : 350, 4spd, 205, 3.42s, 35s
85sierraclassic is offline   Reply With Quote
Old 07-04-2011, 06:44 AM   #5
wyattglock
wyattglock's Avatar
As stated above, I would wire in parallel and install an isolator. Depending on the amount of amperage your stereo will pull at max output, I would probably use 1/0 instead of 1 gauge. It is more expensive and it is also heavier, but it carries a better current with less resistance over the distance you will be running.
wyattglock is offline   Reply With Quote
Old 07-04-2011, 12:15 PM   #6
Hazieview
Yes I will be running two batteries under the bed.
You guys are right. I got them backwards.
I will be wiring the batteries in parallel. (That's what I meant )
Wiring in series would indeed make the power 24 volts which I do not want.
I will be wiring the positive posts together and then just wire the negative posts to the frame.
I pretty much only buy from Summit Racing because I have an account with them. However I can not find the 1/0 cables I need.
I only need around 15' of positve cable and maybe only 3' of negative cable.
I found this one However the description doesn't seem to match the picture because it doesn't show the ground straps. I will also have to buy new post terminals because these are crimped on but it also show they are bare...? Maybe you get to pick...?
http://www.summitracing.com/parts/TAY-21540/
Brand Taylor Cable
Manufacturer's Part Number 21540
Part Type Battery Cables
Product Line Taylor Battery Cables
Summit Racing Part Number TAY-21540
UPC 088197215407
Battery Cable Type Positive or negative
Positive Cable Gauge 1/0-gauge
Negative Cable Gauge 1/0-gauge
Assembled No
Cable Jacket Material Silicone
Cable Jacket Finish Red
Cable Length (in) 240.000 in.
Battery Cable End Style 1 Top post
Battery Cable End Style 2 Bare wire
Adapters Included No
Hardware Included No
Auxiliary Lead No
Quantity Sold as a kit.
Notes Includes 2 eyelet and 2 top post terminals.
When resistance gets tough, the tough get Taylor battery cables. These 1-gauge cables are made from 980 strands of premium 30-gauge copper wire to deliver more cranking power with less voltage drop than most battery cables. They feature crimped tin plated brass post terminals that are less corrosive and three times more conducive than lead. Copper ring terminals for starter and ground connections are included, along with P-clip cable mounts and shrink sleeve tubing for a professional finish.
SB400 350th
Old 07-04-2011, 05:56 PM   #7
juiceman650
I think that should be enough if you're just planning on running (+) to (+).
Old 07-04-2011, 06:09 PM   #8
Hazieview
I think it will definetly be enough for the positive cable. I'm just confused on the other stuff.
Does it have a bare wire end or a crimped terminal?
Does it come with ground wires or not?
I'm going to give thema call and see what they say.
Thanks for all your help guys!
SB400 350th
Old 07-04-2011, 06:27 PM   #9
juiceman650
From what I read and understood, the battery terminals are crimped on, and the extra set of terminals are there if you decide to cut the wire and use a piece for a ground. It looks like 1 giant piece of wire but it could be 2.
Thread Tools
Display Modes
