Old 07-06-2011, 09:05 AM   #1
MikeJones16
MikeJones16's Avatar
k5 Grill Conversion
What would all be needed to do a grill and headlight swap into my 79?
MikeJones16 is offline   Reply With Quote
Old 07-06-2011, 10:27 AM   #2
Pop's C-10
Pop's C-10's Avatar
Re: k5 Grill Conversion
To what kind of gril
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 07-06-2011, 11:32 AM   #3
rayfinseats
Tools
rayfinseats is offline   Reply With Quote
Old 07-06-2011, 11:58 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Thanks for all your valuable input rayfinseats. If you follow his build you might find he is pretty handy with tools for his age. What he needs is information, not wise crack responses.
What year K5 are you wanting to convert to? If your talking about the 88-91 Blazer, or Burb front end you will need the entire front clip including care support.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-06-2011, 01:41 PM   #5
softballnrd27
Always a work in progress
softballnrd27's Avatar
Too bad your up north bc I am going the opposite way you are. I am converting my 82/85 hybrid frontend for a 73-79 front end.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 07-06-2011, 03:35 PM   #6
MikeJones16
I was hoping for the 90 Blazer,
If you type in k10 in google images the first picture you see is the grill I really like.
N2Trux - Thanks for your support. I'll be uploading new pictures later tonight.
Old 07-06-2011, 03:58 PM   #7
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
thats a 88-91 burb/blazer front end. you need everything from the fenders forward. i did the swap to my 84 it's simple and looks nice.
If it aint square, I don't care.
84 C35 CC Dually Project log...
http://67-72chevytrucks.com/vboard/s...d.php?t=414892
1tonchevy is offline   Reply With Quote
Old 07-07-2011, 12:33 AM   #8
MikeJones16
Alright thanks man.
Old 07-07-2011, 01:55 AM   #9
y5mgisi
Second Chance Program
y5mgisi's Avatar
Its really close to a bolt on swap. The only real "big deal" is the rear hood hinges. You have to cut slots in the cowl for the hinges to fall down into.
y5mgisi is offline   Reply With Quote
Old 07-07-2011, 03:31 AM   #10
MikeJones16
Interesting, couldn't I use a hood from the Burb?
Old 07-07-2011, 06:53 AM   #11
motornut
78K & 79C Jimmys
motornut's Avatar
yup
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 07-07-2011, 07:43 AM   #12
jitteryguy
GoatLube Experss
jitteryguy's Avatar
you will need the suburban hood, the issue is your hinge's bolt to your fender's, the later modle hinge's come out of the cowl. it will take some cut'n and weld'n. can be done just more work go'n this way compare'd to put'n the old style clip on a late modle truck
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 07-07-2011, 07:47 AM   #13
RandyP
Getting Old; Going Broke
RandyP's Avatar
Wipers, don't forget about the wipers.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 07-07-2011, 07:58 AM   #14
jitteryguy
GoatLube Experss
jitteryguy's Avatar
we dont need no stink'n wipers ! well mabey he does, probly rains more there than it does over here.
'85 1/2 ton CCSB
'92 S10 350/350
Old 07-07-2011, 01:50 PM   #15
MikeJones16
Okay, thanks guys. After i get tires and rims i'll start going to the junkyard for some parts haha.
Old 07-07-2011, 03:03 PM   #16
thinair
thinair
thinair's Avatar
Make sure that you get the headlight wire harness with it also.
thinair is offline   Reply With Quote
Old 07-07-2011, 05:15 PM   #17
MikeJones16
This is the look i'm wanting. After I buy tires and rims, this will be next.
Thread Tools
Display Modes
