Old 07-10-2011, 07:26 PM   #1
65Guy
Body Roll help.
My truck is a 65 with stock every thing. I want to lower it and rid my truck of the body roll in one foul swoop. What are my options fellas? pic would be nice.Thanks.
65Guy is offline   Reply With Quote
Old 07-10-2011, 08:47 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Body Roll help.
tons, body roll can be lessened by adding front and rear stabilizers.
Lowering it depends on how far you want to go.
front- 2.5" spindles/0-2" springs
rear- all spring? spring/block? bags?
Are you planning on towing and/or hauling heavy stuff with it?
Alot of guys do like, drop spindle with 2" spring for front and rear air bags with adj pan hard bar. sway bars for front and rear for sure.
Food for thought.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 07-10-2011, 10:01 PM   #3
RollinKaos
RollinKaos's Avatar
Re: Body Roll help.
Agreed, easy to do but you have to be honest on what you do with your truck.
I bought the CPP kit with 3/5 drop coils, front and rear sway bars, adjustable trac bar and shocks all in one. HUGE difference, I need front drop spindles still but not ready to convert to disc brakes yet.
Betty :
'63 Fleetside Longbed
350 w/ 4 speed
CPP 3/5 drop with front sway bar.
RollinKaos is offline   Reply With Quote
Old 07-10-2011, 10:20 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Body Roll help.
Depending on what you're currently running, a lot can be done with a decent set of radial tires. Old soggy bias ply tires are notorious for poor handling. New shocks will also help a great deal if the originals are shot.
Old 07-10-2011, 11:51 PM   #5
JohnnyBoy350
Re: Body Roll help.
Mine is sitting on the bumpstops...zero body roll lmao.
-John
If it don't go, chrome it!
JohnnyBoy350 is offline   Reply With Quote
Old 07-11-2011, 10:17 AM   #6
Clyde65
Clyde65's Avatar
Re: Body Roll help.
My truck has a rebuilt front suspension, sway bar and 2" drop coils on the front. rear is waiting on money but my truck handles well considering the arse end is a mile high. eventually I want to do rear air bags, I am buying parts by the month and in a few months I will buy the bags and such.
Clyde65
Rebuild of Clyde
support our troops!
Old 07-11-2011, 10:44 AM   #7
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: Body Roll help.
One option is Mustang II IFS & a 9" Ford rear end.
http://67-72chevytrucks.com/vboard/s...d.php?t=321173
http://www.competitionengineering.co...s/chassis2.asp
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 07-11-2011, 12:34 PM   #8
Slammed50
Re: Body Roll help.
Just as some of the other guys have mentioned you need to know what you want to do with your truck. Daily driver, hauling/towing, what kind of roads you normally drive on is good info too. Your best bet will be to lower your center of gravity by lowering it, either with drop spindles, springs or air bags or a combination of them. Along with that new shocks, front and rear sway bar with bushings, replacing old worn out body mounts and good radial tires will all help solve your body roll problem. Check your control arm bushings and ball joints as well, not much gain in body roll solution but any play in the suspension will attribute to it, besides they are cheap insurance.
Good luck!!
Check out my build thread for my '63:
http://67-72chevytrucks.com/vboard/s...49#post4806049
Slammed50 is offline   Reply With Quote
Old 07-11-2011, 09:41 PM   #9
65Guy
Re: Body Roll help.
Yea I Would love to air bag it but budget is small. I will be using it as a truck, like hauling small trailers and some time haul things in the bed. Like i said before it is bare bones stock.Dont we get a 10% discount at CPP for being on the site?
Old 07-12-2011, 09:51 AM   #10
Clyde65
Clyde65's Avatar
Re: Body Roll help.
Then rear bags would be the way to go, you could get a rear bag setup without the comp and tank for around $300., static on the front with 2.5 spindles and 2" springs, that would probably set you at around $500. rebuild your front suspension parts at the same time, money well spent.
yes we do get the 10% however you will need to contact CPPJEFF when you order.
look at the suspension forum and there are vendors with specials at the top
Clyde65
Rebuild of Clyde
support our troops!
Thread Tools
Display Modes
