Old 07-10-2011, 07:58 PM   #1
krayzog
krayzog's Avatar
Help with differential ID, please.
I am about to order a bunch of parts, to rebuild my differential. I just want to make sure I have what I think I have. Any help will be appreciated.
My truck is a '61 C10 SWB, 327, 3 speed (on the floor now). It originally had an I-6, on the column. I know the engine/trans has been swapped, because my dad and grandpaw did it when I was a little kid (with me over their shoulder, on the creeper... in the way). I know I have a 10 bolt, non-posi, but, is it original or is it another swap that may have happened while I was learning to color in the lines and play well with others?
Also, I counted the ring teeth, divided by the pinion teeth and came up with 3.33. I've had 7,000 chevy trucks (maybe a slight exageration) and I've never heard of that ratio, did I do something wrong?
There have been other mysteries about this truck that I have yet to uncover, like...exactly what transmission it has (doesn't fit any of the sideplate diagrams I've found)...why the starter just decides not to work 1 out of every 4 times...and why the truck seems to HATE MY TOOLS!
I've been lurking for a while, and enjoying every minute of it, but this is my first real post. Again, any help would be awesome!
1961 Apache 10 SWB
krayzog is offline   Reply With Quote
Old 07-11-2011, 01:11 AM   #2
Captainfab
60-66 Nut
Re: Help with differential ID, please.
Welcome to the forum
Yes that is the original differential for your '61. It is commonly known as a Eaton HO55 or just a 55T. They were used from '55-'62. You are lucky that it has the 3.31 gears. Most of these seem to have the 3.90 gears.
From what I can see it looks like a pretty decent truck. And that's cool that it has been in your family for this long. You likely have some fond childhood memories in this truck.
Old 07-11-2011, 08:55 PM   #3
krayzog
krayzog's Avatar
Thanks, Captain. That's exactly what I was needing. Another question; there is some slack between the ring and pinion, not alot, but I would adjust it/shim it if there is some way to do that in this style diff. Do you know. Thank you very much for your help.
1961 Apache 10 SWB
Old 07-11-2011, 09:58 PM   #4
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Is the diff making noise? If not, id leave it alone.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 07-11-2011, 10:04 PM   #5
krayzog
krayzog's Avatar
It doesn't really make noise running, just noticed it kind of clunks now that I have the diff. cover off.
1961 Apache 10 SWB
Old 07-12-2011, 01:00 AM   #6
Captainfab
60-66 Nut
I agree with 61_FL_Apache, unless it is really bad and making noise, I would leave it alone. Trying to fix it would likely cause an issue sooner or later. IMO the best way to fix excessive backlash, is to rebuild the differential.
Old 07-12-2011, 10:51 PM   #7
krayzog
krayzog's Avatar
Thanks, guys. Much appreciated.
1961 Apache 10 SWB
Thread Tools
Display Modes
