Old 07-15-2011, 05:18 PM   #1
kris's66lwb
resident wrencher
1980 propotioning valve
how do you "unpop" a poped proptioning valve
kris's66lwb is offline   Reply With Quote
Old 07-15-2011, 05:31 PM   #2
Dunenutt
Newbee
Dunenutt's Avatar
Re: 1980 propotioning valve
Bleed the brakes by haveing someone push the pedal down. Do the rears first, then do the fronts. Have them lift then re apply every time you close the bleeder. If this does not work replace it.
Dunenutt is offline   Reply With Quote
Old 07-15-2011, 05:50 PM   #3
kris's66lwb
resident wrencher
ok i dont think i have a prob with it i just heard about poping it today and was like what ? is there and easy way to unsticka cliper by chance i know that ther like 40 dollars with the core charge at napa but free is better
Old 07-15-2011, 08:19 PM   #4
LONGHAIR
"Un" popping a proportioning valve requires "balancing" the pressure on both sides of the system. The simplest way is to relieve the pressure on the "good" side by opening a bleeder and applying pressure to the pedal. It can "pop" back at the end of the travel. It doesn't always work that easily though. Sometimes it takes a good "slam" of the pedal (with the bleeders all closed) It is really more about "speed" than the amount of pressure applied.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Thread Tools
Display Modes
