Old 07-18-2011, 11:27 AM   #1
Gator70
Gator70's Avatar
chasing a ground problem
So, I have a ground issue with my tailights. When i took the lens housings out the mounting screws had some sort of rubber?? behind them. Is that rubber, or something else. The screws hold the assy against the box and help create the ground. If it is rubber what creates the ground for the assy??
Any advise would be good, my beer budget is getting shot trying to chase this problem down.
1970 GMC K15 - Canadian built
2nd Owner truck 68k miles
2014 Denali 1500 6.2L
Gator70 is offline   Reply With Quote
Old 07-18-2011, 12:25 PM   #2
BADPURPLE70CHEVY
406 Powered
BADPURPLE70CHEVY's Avatar
Re: chasing a ground problem
When i put my bed back together i had a similar problem. Turned out to be a ground wire in behind the taillight assembly. GOOD LUCK
70 GMC
68 c10
2002 silverado
72 4x4
BADPURPLE70CHEVY is offline   Reply With Quote
Old 07-18-2011, 12:33 PM   #3
cdowns
cdowns's Avatar
i always run a ground cable from one of the crossills of the box to either a crossmember or frame rail to ground the box to the frame /it solves alot of problems
Old 07-18-2011, 12:34 PM   #4
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
That stuff behind the screw is sealer. I use 3M Strip Calk adheisive in its place. It keeps water from getting inside the housing from the back side. The housing will ground to your bed once the screws are tightened. How does your sockets look? Or the taillight harness? WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 07-18-2011, 01:07 PM   #5
Gator70
Gator70's Avatar
Thanks for the tips. I am trying to avoid pulling the whole harness out, but the sockets/connections are in suprisingly good shape. I can only feel up to the marker light splice and it feels pretty good. The nut clips for the mount screws are pretty rusty, I am going to try and get those off and clean them up.
I dont recall seeing a ground wire on the wiring diagram, or part of the harness. Where is that wire. The marker lights have the single lead and then grounded to the box. But I didnt see anything for tailights or back-up lights.
Old 07-18-2011, 01:11 PM   #6
Classic Heartbeat
The taillight housing and backup lamp housing do not have seperate wires to ground them. They are grounded through their housings. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 07-18-2011, 01:21 PM   #7
Gator70
Gator70's Avatar
Thats what I thought Wes. Thanks. Maybe another wire like cdowns said would help things out. 40yr old connections can be a little fickle.
Thread Tools
Display Modes
