07-19-2011, 04:57 PM | #1 |
Straightening slightly overbent U bolt - how??
One of the new U bolts for the coil rear on my 70 is slightly overbent on one side. How would I go about straightening it enough so I can get through the pads on the axle (or at least hold it open to get it on)? It's about 1/8"-1/4" bent in too much on one side. It doesn't look like a BFH would do it. I can get pics soon if it would help.
1970 Chevy LWB - 305/350 In Progress: 4/6 ECE drop, front discs, power brakes, Coys C5's. |
07-19-2011, 05:10 PM | #2 |
Re: Straightening slightly overbent U bolt - how??
I would put one side in a vice horizontally, then using a large pipe that you can slide over the other end slowly pull or push the u-bolt. Depending on what you need. I would also protect the threads before straightening.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
07-19-2011, 05:14 PM | #3 |
Thanks! Didn't even think of that one. I'll give that a try.
Dan
07-19-2011, 08:31 PM | #4 |
Thanks again. That worked like a charm
07-19-2011, 09:34 PM | #5 |
Your welcome
Thread Tools | |
Display Modes | |
