Old 07-24-2011, 09:22 PM   #1
Envy
Envy's Avatar
Fuel lines?
I need to do all the lines for my restoration, any advice on to where to get complete kit to build my lines. I want to hard line from tank in rear to fuel pump, using hose to connect lines to tank and lines to motor. Wanting aluminum or stainless, and need lines, hose, fittings, tools, and frame mounts.
Where should i look
Envy is offline   Reply With Quote
Old 07-24-2011, 11:07 PM   #2
tooslo60
tooslo60's Avatar
Re: Fuel lines?
Jegs, Summit, Napa, Carquest, anywhere really.All the mail order places ship them in a big coil though, so if you want straight lines go to your local parts store.
tooslo60 is offline   Reply With Quote
Old 07-24-2011, 11:10 PM   #3
'63GENIII
'63GENIII's Avatar
Re: Fuel lines?
Im doing all mine in -6 fittings. My first time. Getting all my fittings from my local independent. He made it sound real easy. Single flare kind of easy. Im running braided steel lines to the tank in the rear with aluminum hard line all the way up to the factory fuel inj. hoses
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 07-25-2011, 03:28 PM   #4
Turkey
Turkey's Avatar
Re: Fuel lines?
classic tube treated me right....fit right and tightened right up
Turkey is offline   Reply With Quote
Old 07-25-2011, 04:16 PM   #5
kieth
kieth's Avatar
Re: Fuel lines?
auto zone will sell you the lines, and rent you the flare tool and bending equipment to make your own custom lines. Kieth
kieth is offline   Reply With Quote
Thread Tools
Display Modes
