Old 07-25-2011, 07:03 PM   #1
CEE1NG_RED
Which ATF type to choose??
...need some insights. Is DexMerc ATF any good?? I bought a 'Coastal' brand ATF DexMerc from Autozone for $14.99 (1 GAL). Guy said DexMerc is what old GM/FORD use. Or shoud I get a high mileage ATF? Also, what type is best (Dextron, F, etc)? How many quarts will I need? I am going to drop the trans. pan tomorrow and fix the RTV leak w/ a rubber gasket. FYI: It's a 67 C10 with a TH350 transmission. Mileage is unknown, but I'm assuming it's high.
- 1967 Chevrolet C/10 SWB fleetside (New Project).
- 1969 Chevrolet C/10 SWB fleetside (SOLD)
- 2000 Ford Mustang 232 (DD)
- 2003 Ford SVT Cobra "Terminator" 281 (Once in a blue moon driver/weekend driver)
CEE1NG_RED is offline   Reply With Quote
Old 07-25-2011, 07:48 PM   #2
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
Re: Which ATF type to choose??
Dex 3 is what i would use
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 07-25-2011, 09:12 PM   #3
sjarrett71
sjarrett71's Avatar
From what I remember the Type F is a no no in GM vehicles. Everything I've ever read or seen says Mercon/Dexron for GM vehicles. As for the high mileage stuff that would be a matter of opinion.
-Scott-
sjarrett71 is offline   Reply With Quote
Old 07-25-2011, 10:05 PM   #4
69heavychevy
69heavychevy's Avatar
dex/merc...house brand works just fine
69heavychevy is offline   Reply With Quote
Old 07-25-2011, 10:30 PM   #5
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
max shift from tci enuff said
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 07-28-2011, 10:17 AM   #6
CEE1NG_RED
...WHEN dropping the trans. pan, will I need to remove the entire ATF before pouring in new trans fluid? I just want to fix the leak caused by the RTV on the pan and replace it with a rubber gasket and change the filter. Will it hurt the transmission if I do it that way (Just refill the trans. with new ATF that is mixed with the previous ATF). The PO I believe put Dot 3, BUT I'm just adding ATF DexMerc, which meets Dot 3 specs as well. PLEASE let me know if this will be fine? I will be doing this after work today. [sigh]
Old 07-28-2011, 10:30 AM   #7
truckster
truckster's Avatar
You don't need to get all the fluid out, unless it looks or smells burned.
truckster is offline   Reply With Quote
Thread Tools
Display Modes
