Sloppy Steering - Help!
Finishing up my frame-off restoration on a 72 LWD C10 and we did not touch the front end suspension or the steering wheel shaft. We thought we would address that once we could drive the truck and see what it needs - well, we are at that place and the steering wheel has a lot of slack or slop in it. You can move the steering wheel left and right very easily without moving the tires. This is the case both sitting still and rolling.
What normally causes this problem on a 72 C10 long bed with power steering, so I can head in the right direction? Pitman arm, tie rods, steering shaft, steering box, power steering pump, power steering pump belt, etc? Thanks in advance for all assistance in this matter. KellerMac
Texas - Don't Let The Size Scare You! |
Laid Back
![]() Join Date: Apr 2010
Re: Sloppy Steering - Help!
Gear box
72 chevy swb Direct dealers for.. Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body.. Kyle http://67-72chevytrucks.com/vboard/s...d.php?t=574629 |
Have someone slowly turn the wheel without turning the tires and watch each steering component. See what moves and start there. Just went throw this on my 72 with power steering. After new control arm bushings, ball joints, tie rod ends, pitman and idler arms, and a reman steering box it's tight and responsive.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Don't forget the rag joint.
Thanks guys - does the rag joint make that big of a difference?
I am a Referee of life.
It can.I had one break.It will get really sloppy then.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
I have ALWAYS got a ton of bang fo my buck with a new Idler Arm first. On one truck I had probably half the steering wheel of play and you could literally not keep it on the road and the idler arm took it down to under a couple of inches. Just my take but I always start with that and they are not much. Then take it from there if there is still too much play.
Like Lee says get under it & pull & tug & make a note of all the things that have any slack in them. Watch the pitman arm. That is a comon place for a lot of slack. Put a jack under each lower control arm. That frees up the ball joints & upper shaft. Push & pull the wheels & check for looseness. Watch the lower shaft on the steering gear as someone turns the str. wheel back & forth. If it has side motion the brg. is bad. If not you can adjust the secter adj. on top by turn it down a litle. Just 1/8 -1/4 turn is all you want to do. Its probably a combiation of all the above suggestions.
Thanks Guys! I will heed all your advice and see if I can solve my problem!
Lay underneath it while someone is slowly turning the wheel right and left and you will be able to spot what is worn. Look closely at the steering box too to make sure its mounting bolts haven't loosened up letting the box move some. I had that happen before and replaced a lot of components before having someone turn it while I was watching.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
Who's got steelies?
![]() Join Date: Feb 2006
Loose wheelbearing will make it sloppy too. It will also give it a "wandering" feel when driving.
![]() ![]() ![]() ![]() ![]() ![]() How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
Thread Tools | |
Display Modes | |
