Old 07-28-2011, 06:31 AM   #1
Andy4639
Old member
Andy4639's Avatar
Question Speedo cable
I'm fixing to install my GPS speedo and want to know what to do about the cable hookup on the transmission. Should I just take it loose and leave it are cut the old connection off and place it on the tranny.
Do they make a cover for it. I have a 700-R4 transmission.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 07-28-2011, 09:41 AM   #2
cdowns
cdowns's Avatar
Re: Speedo cable
i've never had this problem
i i were to go that route i'd remove the speedo gear housing and make a custom plug up to put into the tranny case and have it held in place with the bolt that holds the speedo sender in place
Old 07-28-2011, 09:52 AM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Speedo cable
cdowns,
I have thought about that also.
Transmission guy said put a freeze plug in it and forget about it.
That sounds simple enough!
Thread Tools
Display Modes
