Old 07-28-2011, 08:09 PM   #1
mweishaa
Turn signal wiring on 64 GMC 1500
OK, so I got my new turn signals in, now it's time to wire them. The painters just cut the wires but there's a portion of the wiring running in within the hood. So I have the original light blue, dark blue, and violet wires.
I took the wiring diagram from the manual and "erased" everything I didn't need. Here's the pic:
I wired it up just as shown here. Here are my results:
1. I have no parking lights (but the rear lights do work in parking mode.
2. When I engage the left signal, BOTH signals blink bright (bottom bulb filaments).
3. When I engage the right signal, only the right one blinks, but dimmer (using the bottom filament).
In both cases, the turn signal indicator on the dash blinks.
I'm pretty stumped. I removed the light blue wire from the firewall, and got the exact same results. If I remove the dark blue wire, both blink for left, netiehr for right. The dash indicator still works for both. If I remove the violet wire (supposed to go to the light switch connector) then I get nothing.
Now the ONLY thing I didn't do per the diagram was have the violet wire connected at the left light and then to the right light. But they're connected together, more in a Y... i.e. the wire comes from the firewall to the middle of the hood, then does a Y to both lights.
OK wiring gurus, what's going on? It appears I have the original wiring, so I would expect it to all be intact.
I took the voltages at the engine side of the firewall of the 3 connectors. There were no wires running, so I was getting a good ground.
voltages are for the Top/Left/Right connector
Parking light on - 0/0/0
Left signal on - 0/12/12
Right signal on - var/0/var
var = varying voltage... so, blinking.
Per the diagram it should be Top (right signal), Left (left signal), Right (parking)
I think I'm going to have to dig into the parking light switch and do some wire tracing to the signal switch now.
mweishaa is offline   Reply With Quote
Old 07-29-2011, 09:38 PM   #2
scotts62
One day...
scotts62's Avatar
Re: Turn signal wiring on 64 GMC 1500
ttt
Scott
93 crew cab build
Project 62
Old 09-21-2011, 11:35 PM   #3
chris86
chris86's Avatar
did you ever figure it out
i got the same problem
chris86 is offline   Reply With Quote
Old 09-22-2011, 09:33 AM   #4
mweishaa
I haven't taken the time to go any further with it. I had some other things I needed to do on the truck, and it's just been too damn hot here. I'm kind of laying low until we get a break from our heat. (supposed to be 106 for the next week!)
Old 09-22-2011, 10:23 AM   #5
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
One thing you shouldnt forget is to use a ground strap from the hood to the body.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Thread Tools
Display Modes
