Old 07-30-2011, 01:42 PM   #1
bean
Trailing arm bushing replacement
how hard is this to do? mine are pretty rough. anyone done this before?
bean is offline   Reply With Quote
Old 07-30-2011, 01:47 PM   #2
Indyuke
Re: Trailing arm bushing replacement
I'm wondering the same. It's the last thing I need to do to complete my suspension rebuild.
Indyuke is offline   Reply With Quote
Old 07-30-2011, 01:49 PM   #3
stich626
it's not bad,
I burned out my old ones and used ploy graphite new,
stich626 is offline   Reply With Quote
Old 07-30-2011, 01:51 PM   #4
bean
i have to ask can you give steps to replacing them?
Old 07-30-2011, 01:53 PM   #5
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
If you want to burn the old ones out then you must remove the trailing arms first. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 07-30-2011, 01:56 PM   #6
bean
i just want to replace the bushings they are pretty cracked and worn. this is a work truck i use mostly on weekends.
Old 07-30-2011, 06:21 PM   #7
eagleuh1
eagleuh1's Avatar
Get them pressed out. I like the not burning them out while installed post. I can picture someone with a torch down there catching their truck on fire and then blaming you stitch626.
eagleuh1 is offline   Reply With Quote
Old 07-30-2011, 06:35 PM   #8
BossHogg69
motor exploder
BossHogg69's Avatar
Just unhook the arms from the front mounts, drop them down, drill a bunch of holes in the rubber around the bolt hole sleeve, knock out what's left with a big socket that's the same size as the bushing hole. Then pop in the new poly ones with a little lithium grease, or whatever is provided with the new bushings. No torch needed. If they are as rotted as mine were, they won't put up much of a fight.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 07-30-2011, 06:36 PM   #9
eagleuh1
eagleuh1's Avatar
Wish I had a working scanner, could send you or post the manual pages on this. Pretty much jack up the truck, Block the front wheels, and back wheels to keep axle from moving. Place jack stands at rear on frame, not under axle.. Spray all the u-bolts on axle with PB Blaster after wire brushing. Spray the bolts at the trailing arm bushing and the drive shaft u joint bolts if you plan to remove this. I'd just put something under to hold up the front at the axle. Unclip the brake lines and parking brake cables from the trailing arms. Then remove axle u-bolts and bushing bolts at front of trailing arms.
That should be it. Put back in and retorque. Good luck. Jim
Old 07-30-2011, 06:47 PM   #10
stich626
I took my arms out. as now was the time to clean and paint them and it's only 6 more nuts and they are out.. no truck to burn down..
even in the truck how you think shops did it.. anyway.. be safe.
Old 07-30-2011, 07:01 PM   #11
eagleuh1
eagleuh1's Avatar
Those look nice and clean stitch. I wasn't in any way saying that someone would do that in the truck, just laughing because someone had to say not to do it when installed. Thats all. Jim
Old 07-30-2011, 07:59 PM   #12
stich626
ya I get it, like a coffee cup needing to say "hot"
was it train or brain he say
today I wonder where common sense went
Old 07-30-2011, 09:27 PM   #13
hayhauler71
hayhauler71's Avatar
I used my balljoint press and pressed them right out
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 07-30-2011, 09:42 PM   #14
stich626
thats great the poly don't come with outer metal, now what..
royal p.i.t.a.
Old 07-30-2011, 09:44 PM   #15
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
toshay
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 07-30-2011, 09:48 PM   #16
ETsC10
Hand Crafted C-10
ETsC10's Avatar
There are also hand tools to get the job done.
This one is from Snap-on, driven by an impact wrench.
ETsC10 is offline   Reply With Quote
Old 07-30-2011, 09:52 PM   #17
stich626
Originally Posted by fastwillie 696969 View Post
toshay
do the rubber replacements come with new outer sleaves?
the poly don't, pressing them out takes the outer with it..
Old 07-30-2011, 10:00 PM   #18
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Yes, the rubber replacements come with a vulcanized in place outer metal sleeve. The urethane bushings do not and require you to reuse the original outer shell, making installation much easier since you don't have to press the outer shell out.
Old 11-23-2011, 10:30 AM   #19
OJ1988
Just a car guy
OJ1988's Avatar
I tried burning mine out, was not very effective, so I switched to drilling.
I broke a couple small drill bits off in them.
I did not remove the trailing arms from the rear axle. Do I was Domingo this with the arms under the truck. The bed is off so that made things easier.
For installation, I was able to get the bushings about halfway in by hand, then had to use a c clamp to get them the rest if the way in.
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
Old 11-23-2011, 10:52 AM   #20
Hart_Rod
Hart_Rod's Avatar
Burn 'em!!!
Hart_Rod is offline   Reply With Quote
Thread Tools
Display Modes
