Old 07-31-2011, 05:48 PM   #1
mongoose
mongoose's Avatar
Is this okay to do?
i have my tuck set up on the front with 2600's with out cupped arms or lower cups, ie the bag is just sitting in the stock spring pockets. is this okay to do? or should i change it out?
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 07-31-2011, 05:52 PM   #2
texastrendz
Re: Is this okay to do?
i would not do that. you need some type of locating device. lots of options and opinions on the topic. i used a bag plate to locate mine, cups also work just as well. you can purchase both from many vendors found in the suspension section.
texastrendz is offline   Reply With Quote
Old 08-01-2011, 02:53 AM   #3
weekendracer728
weekendracer728's Avatar
U r at risk of blowing a bag
Live life one weld at a time.
'04.5 Chev Duramax CCLB- Winter DD
'03 Grand Prix GT- Summer DD
'67 C10-307/T5(For Now)-R.I.P-Burned Up!
'68 C10-5.3/4L80E
www.one-guys-garage.com
weekendracer728 is offline   Reply With Quote
Old 08-01-2011, 02:22 PM   #4
dv8customs
dv8customs's Avatar
You at least need a cup to help keep it centered
dv8customs is offline   Reply With Quote
Old 08-01-2011, 03:40 PM   #5
kieth
kieth's Avatar
Are you saying it needs a metal ring around the base of the bag along with the bolt that locates it in the center ?
Should the bottom plate be angled to allow the bag a more vertical alignment ? along with a ring for support.
kieth is offline   Reply With Quote
Old 08-02-2011, 03:27 AM   #6
mongoose
mongoose's Avatar
what had me more concerned is the rubber parts of the bag touching the edges of the spring pockets
if it's just locating it that's the prob i could bolt it to the lower control arm no problem.
Old 08-02-2011, 09:56 AM   #7
texastrendz
http://*******************/bag-bracke...er-airbag-cups
Here ya go brother:
Old 08-02-2011, 11:08 AM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
You need a cup to keep it centered AND prevent it from chaffing. If the bag rubs, it will fail. You do not want it bolted on the bottom.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-02-2011, 11:42 PM   #9
mongoose
mongoose's Avatar
k. guess im putting the cups back in lol..
took em out as it gave the proper ride height at a decent pressure level.
Old 08-05-2011, 02:20 PM   #10
dubds10
Stalker Nate
You can always just cut down the cups to the required height you need, but you should run cups and trim out the spring pockets if they bags are running close to them.
1957 GMC SWB stepper modified summer time driver
1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project
1965 Chevy P10 Ice Cream Truck project
Instagram - TheDonutDiner
FaceBook - @UscreamIscream
dubds10 is offline   Reply With Quote
Old 08-05-2011, 09:06 PM   #11
mongoose
mongoose's Avatar
yeah ill probably do that.. they seem to be closest to the shock mount so i should be bale to take a notch out of the arm there and be good.
Old 08-06-2011, 01:10 AM   #12
dubds10
Stalker Nate
Don't notch the control arms unless you plan on filling them and can weld properly lol Unless you mean the spring pocket you're cutting, cause that's fine. Just make sure to grind it down and smooth it out.
Thread Tools
Display Modes
