Old 08-02-2011, 04:37 PM   #1
sinnersahuayo
carb
would this work on my 1965 c10 V8, rasie or air gap intake, this the carb that on craglist- HOLLEY 500CFM 4 BARREL CARB for 130http://seattle.craigslist.org/kit/pts/2491377195.html. right know i have a holley doulbe pump, unkown CFM, both are manual choke.
sinnersahuayo is offline   Reply With Quote
Old 08-02-2011, 05:47 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: carb
I don't think you'd want that on a street engine since the choke horn is missing (on purpose). I believe this is designed to be used in a dual carb setup like a tunnel ram, and the other carb would have the choke assembly.
To work in a single 4 barrel application the choke area should look more like this:
http://www.holley.com/0-80450.asp
Old 08-02-2011, 06:57 PM   #3
sinnersahuayo
Re: carb
i have cleaned my carb and still doesnt want to start i have to add quick start spay only to start. i have adjust the choke and still doesnt want to start any tips.
Old 08-02-2011, 10:58 PM   #4
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Re: carb
You absolutely do not want that carb. It's not a 500 cfm....it's a 450 cfm list 9776. It's a tunnel ram only carb and is calibrated to be ran in pairs. It's a mechanical secondary with no rear accel pump. It would be a nightmare on any motor being ran by itself.
prostreetC-10 is offline   Reply With Quote
Old 08-03-2011, 11:54 AM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: carb
Also... if you got a double pumper on the current engine set up you're probably way over carbed. Especially if it's a stock or stockish "V8". Not many street engines need a DP.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 08-03-2011, 07:11 PM   #6
sinnersahuayo
Re: carb
i think its the carb, it really hard to getted started cold or hot, i have to use quick spray to getted started. any fix or any other ideas
Old 08-04-2011, 11:39 AM   #7
GASoline71
GASoline71's Avatar
Re: carb
A different carb. Holley 1850 or an Edelbrock 1405 or 1406. Both are 600cfm's.
Gary
Thread Tools
Display Modes
