08-03-2011, 05:05 PM | #1 |
72 differential oil/fill line?
what do you all suggest for differential oil and how much do I put in... is there a fill line or something... I am getting ready to go out and take cover off cause it is leaking from bottom (since I bought truck) and re-seal. Then put new oil in..... what do you all suggest, is there a simple way to know when it is full
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP SOLD 1972 chevy c10 |
08-03-2011, 05:12 PM | #2 |
Quit if it's not FUN!!!
Re: 72 differential oil/fill line?
Me too!!
08-03-2011, 05:14 PM | #3 |
3-4 quarts, Royal Purple is good stuff
08-03-2011, 05:15 PM | #4 |
Always been told fill it until rear end oil comes out fill plug.
Posted via Mobile Device Posted via Mobile Device |
08-03-2011, 05:24 PM | #5 |
~Rest In Peace~
remove the drain plug first before poppin the cover off ,basic open diff. 2qts 75-90 w gear oil Quaker state or Lucas lubrication ,take a ball peen hammer and slight tap the bolt holes flat and clean off surface to prep for silicone gasket sealer ,install the cover with the rtv ,tighten the bolts 20 ftlbs ,add oil to the drain hole on the side of the rear just when it drips out put the plug in
if its posi used the synthetic oil
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
08-03-2011, 05:24 PM | #6 |
08-03-2011, 05:51 PM | #7 |
cool thanks..... I don't think it is posi, unless it came that way from factory... I think it is the factory 3.73
08-04-2011, 11:54 AM | #8 |
Put the additive in for Posi too if you have a posi. I like to overfill mine a little so it runs out to the axle tube ends. I just force it in after it overflows a little then put the plug in real quick. Jim
08-04-2011, 12:05 PM | #9 | |
Florida Edition
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
08-04-2011, 12:10 PM | #10 |
thanks guys got it all done....
08-04-2011, 12:41 PM | #11 |
i use royal purple 2quarts for a 12bolt rear// no drain plugs on a 12bolt/ no additives required with royal purple or most synthetic gear oils nowadays
check the bolt holes of the cover and make sure they are flat overtightening causes them to "bell" out and cause poor sealing and leaks
08-12-2013, 11:41 AM | #12 |
Do you put the new cover on almost all the way they add oil if you have the 12Bolt?
1972 C10 Custom Deluxe 2 Owner Project "Lumberjack" 83K Original miles Work in progress....Got the truck for free all original |
08-12-2013, 12:05 PM | #13 |
There is fill plug on the pinion side. Takes a 3/8 square drive to remove.
Synthetic gear oil in the rear axle is a perfect application.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
08-12-2013, 01:34 PM | #14 |
Thanks Bigdav160
08-12-2013, 08:00 PM | #15 |
YMMV but I haven't had any luck keeping it from leaking unless I let it set up overnight before I fill it up.
08-12-2013, 09:35 PM | #16 |
Watch out for your cornhole !
A new FelPro cover gasket is cheaper than a tube of silicone. It's also quicker and looks more sanitary than silicone does.
08-13-2013, 01:33 AM | #17 |
20' Daredevil (Ret)
If you decide to use silicone anyway..... use this stuff, it's made for gear oil.
03-10-2020, 05:03 PM | #18 | |
03-10-2020, 05:29 PM | #19 |
My 8+ inch 12 bolt only held 1 and a quarter quart using a stock stamped cover. -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
03-10-2020, 06:16 PM | #20 |
Can anyone suggest a different cover from the stock steel one ? Mine is rusty !
71 C-20 07 Magnum RT AWD |
03-10-2020, 06:50 PM | #21 |
Hold on to your rusty one, an aftermarket one will not be as good. I took mine off when I drained it to refill with new oil. While it was off I cleaned it up and painted the outside, and stuck the bolts through a piece of cardboard and painted the bolt heads. The inside was very nice with no rust due to being constantly exposed to oil. I used a POR-15 starter kit from Amazon.com, it was quite inexpensive and the whole job just took a couple teaspoons of paint. A little goes a long way with POR15. Do not get POR15 on anything you don't want painted permanently, such as your hands. It will not come off. Make sure the lid and top lip of the paint can are perfectly clean when you re-close the can, or the lid will not come off again the next time you have a little rust-proofing project. Dip into the can with a plastic spoon and transfer the paint to a disposable container such as a pie tin, so you don't contaminate the paint. This gives you an excuse to start the job by eating pie.
03-10-2020, 07:12 PM | #22 | |
When I replaced the Chevelle 12 bolt with a 9 inch. I had a new fill added and a drain plug drain plug is protected by the fing on the bottom . I added the one picture that looks like its chrome just cause I like it
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 03-10-2020 at 07:19 PM. |
03-10-2020, 07:14 PM | #23 |
20' Daredevil (Ret)
You have a fill hole though, right? Remove the cover to drain the diff.
03-10-2020, 10:28 PM | #24 | |
Who Changed This?
A clacking noise will probably be a u-joint.
03-11-2020, 05:14 AM | #25 | |
Thread Tools | |
Display Modes | |
