Old 08-05-2011, 10:53 AM   #1
Cooper1972
Heat causes starter to freeze
My grand dad just gave me his 72 sportvan, which he purchased new. He told me at times when its hot out, and the engine is hot (not overheated) the starter will freeze up due to the heat from the exhaust pipe which runs down next to the starter. It has a 350 engine. My question is does anyone know what I could use to insulate the starter from the exhaust pipe to keep the starter from over heating. He said in the winter it does not happen. My new van is in pristine condition and I love it.....Josh
Cooper1972 is offline   Reply With Quote
Old 08-05-2011, 11:20 AM   #2
Steve Hafner
Steve Hafner's Avatar
Re: Heat causes starter to freeze
I bought one out of the LMC catalog and it cured the problem for me. You can make one easily. Here's the link to the homemade one below:
http://67-72chevytrucks.com/vboard/s...d.php?t=465300
Life is short . . . we only have, right now.
My 70 C-10's BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=475526
Steve Hafner is offline   Reply With Quote
Old 08-05-2011, 11:21 AM   #3
Wbrown
Wbrown's Avatar
They sale starter covers from jegs for around 25 dollars. I bought one for my rock crawlers.
Master welder
I've got a degree in metalfusionology
Wbrown is offline   Reply With Quote
Old 08-05-2011, 09:33 PM   #4
litew8
litew8's Avatar
You could probably make your own. Sheetmetal + snips. Maybe even use an empty can of peas or corn.
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 08-05-2011, 09:53 PM   #5
Lee H
Lee H's Avatar
Welcome to the site! Wrap the header pipe next to the starter with header wrap. A high torque mini starter would also help.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is online now   Reply With Quote
Old 08-05-2011, 10:38 PM   #6
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
disposable turkey pan
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 08-06-2011, 07:22 AM   #7
jondancer
Yeah my truck does that too. Post pics of the van!
jondancer is offline   Reply With Quote
Old 08-07-2011, 02:15 AM   #8
litew8
litew8's Avatar
nice call. dissipate heat quicker your way. pea or corn can for exhaust patch.
Old 08-07-2011, 02:43 AM   #9
wwotr
wwotr's Avatar
They make an insulated starter wrap/blanket too.
I had the same problem on my 70 Camaro.
Once in awhile I'd forget and turn the engine off. I'd have to wait 45-Hour for that S.O.B. to "Cool Down", before I could start it and take off!
Hello members...
I'd like you to know that I sold,
my 72 GMC (Ratikle),
back in November of 2011.
I don't visit the site much anymore,
but please feel free,
to drop me a private message.
RIP...."RATIKLE"
wwotr is offline   Reply With Quote
Old 08-07-2011, 04:18 AM   #10
69heavychevy
69heavychevy's Avatar
had the same problem then i installed one of the "newer" style GM gear reduction starters and it solved the problem, heat shield would probably be a cheaper alternative though...
69heavychevy is offline   Reply With Quote
Old 08-07-2011, 06:13 AM   #11
landsurvey1
landsurvey1's Avatar
I was having heat soaked starter solenoid problems, I bought a remote solenoid from summit and it fixed my starting issues.
landsurvey1 is offline   Reply With Quote
Old 08-07-2011, 11:37 AM   #12
mbgmike
Thats really the way to go
mbgmike is offline   Reply With Quote
Old 08-07-2011, 11:39 AM   #13
mbgmike
Thats why ford did not have a problem theres are remote. we sell the relocation kit for $20.00
Old 08-07-2011, 01:37 PM   #14
Shyguy
Junior Member
Shyguy's Avatar
Do you have a part number for the GM reduction starter? I will probably need one when we put the 454 in my '67.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 08-07-2011, 02:23 PM   #15
stich626
99 trucks and suv
stich626 is offline   Reply With Quote
Old 08-07-2011, 02:29 PM   #16
Sinister
Between Trucks...
Sinister's Avatar
This worked for me as well.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 08-07-2011, 03:03 PM   #17
Shyguy
Junior Member
Shyguy's Avatar
Originally Posted by stich626 View Post
99 trucks and suv
Thank you for the information.
Old 09-24-2011, 06:33 PM   #18
67Slider
67Slider's Avatar
Hey Mike,
I couldn't find the kit on your website. I wil PM you.
Matt
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline   Reply With Quote
Old 09-25-2011, 08:38 AM   #19
This is a sign of an aged starter that will end up failing you. You don't have this problem with a healthy starter/solenoid. I just replace the starter with an OEM type and have never used a heat shield or any fancy starter. Works for me. A heat shield helps prevent heat from killing your starter prematurely due to headers being so close. But again,I've never had a starter fail so often that I've felt the need to add a shield. I run headers on everything.
Old 09-25-2011, 10:27 AM   #20
67Slider
67Slider's Avatar
I tend to agree. It was the starter that came with the truck when I bought it. It heat soaked on the first drive home. So it was probably and existing problem. I thought I could get away with a shield but I am leaning toward a ministarter and the remote solenoid to combat any future problems. I like how the remote solenoid offers easy access and you can reroute the wires.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
Old 09-25-2011, 02:16 PM   #21
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Here's a couple of wiring diagrams for the remote solenoid.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 09-25-2011, 06:11 PM   #22
67Slider
67Slider's Avatar
Awesome. Thanks VetteVet.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
Old 09-25-2011, 09:06 PM   #23
Shyguy
Junior Member
Shyguy's Avatar
Attachment 805461
Attachment 805462
Thank you for posting the wiring diagrams, I saved them for future reference when I put a remote solenoid on my '67 project.
Old 09-25-2011, 09:33 PM   #24
67Slider
67Slider's Avatar
Knocked this out this evening. Thanks to all who helped. I am still thinking about replacing the starter but will probably wait to see how this has helped. It was pretty easy and went well. I ran the wires away from all heat sources. Cost about 30 bucks for the solenoid, some 10 gauge wire and a new battery cable.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
Thread Tools
Display Modes
