Old 08-11-2011, 01:26 AM   #1
blu-by-u-2
blu-by-u-2's Avatar
Ooops cut to much.
Lowered the front last weekend. Cut the coils to much... I am going to get me another used set soon. My question is can I go with air shocks in the front I have them in the back. I need new front shocks any way and I figured if I go with air shocks I can fill with extra air for the meantime.
77 k5 2wd
76 k5 jimmy 4x4
97 c1500 2wd
06 chrysler 300 on 22"s
blu-by-u-2 is offline   Reply With Quote
Old 08-11-2011, 10:28 AM   #2
blazer2007
Re: Ooops cut to much.
I got geedy too and cut and cut until too late but looked good,don,t know about air shocks, could give them a whirl
blazer2007 is offline   Reply With Quote
Old 08-11-2011, 10:45 AM   #3
SCOTI
SCOTI's Avatar
I've never seen an airshock for a c-10 front suspension application. Buy new springs.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-11-2011, 10:46 AM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
buy new springs, also you might consider replacing your sway bar mounts to the lower profile mounts for lowered applications.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 08-11-2011, 10:52 AM   #5
SCOTI
SCOTI's Avatar
Or, you can remove the existing mounts & trim the sway-bar bushing bracket (piece that holds the bushing in place) so it fits on the top side of the existing bracket vs under it. Then reinstall the mounts w/bolts. This relocates the sway bar higher for sweat equity.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-11-2011, 11:01 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
No, you do not want air shocks. Even if you find a set that will fit, they will ride like crap. Do yourself a favor and use a good quality replacement shock once you get the spring issue corrected.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-11-2011, 12:05 PM   #7
lolife99
67-72 parts collector,…
lolife99's Avatar
How much spring did you cut?
1/2 coil usually equals about 1" of drop.
Keith
Convert to disc brakes.
Old 08-11-2011, 08:13 PM   #8
LONGHAIR
No, to the air-shocks. The mounts can't take the weight of the truck, they will break something...
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 08-11-2011, 11:03 PM   #9
blu-by-u-2
blu-by-u-2's Avatar
Thank you guys, picture (1) before I began. picture (2) 1st coil cut on driverside, way too much tire rubbed wheel well. picture (3) 2nd set coils too much. I hope the third set will be the last. I hope I don't screw things up when I go do the back.
77 k5 2wd
76 k5 jimmy 4x4
97 c1500 2wd
Thread Tools
Display Modes
