Old 08-11-2011, 09:38 PM   #1
texastrendz
Drive shaft angles with 2 piece drive shaft
Trans angle at yoke 6*
First shaft angle 5*
Second shaft angle 4*
Pinion angle 3*
Am I even close ?
Any and all help would be great, Nate, help a brother out. lol
texastrendz is offline   Reply With Quote
Old 08-11-2011, 11:57 PM   #2
Slammed50
Re: Drive shaft angles with 2 piece drive shaft
Not too familiar with the two piece dive shaft but so far my magic number at the tail shaft is 3* down and the pinion matching at 3* up. From my experience it seems like you may need to take another stab at your angles, maybe try some shims.
Check out my build thread for my '63:
http://67-72chevytrucks.com/vboard/s...49#post4806049
Slammed50 is offline   Reply With Quote
Old 08-12-2011, 11:28 AM   #3
PBFAB.COM
PBFAB.COM's Avatar
Pinion angle 3*
Am I even close ?
That would make the operating angle at the trans pinion/front shaft 1* and the operating angle at the rear pinion/rear shaft 7*
Looks like you will need to make a couple adjustments. I would shim the carrier up a little more and re-check the angles to see where you land... then most likely a shim on the rear diff.
You will have to make one change at a time, re-check the slope of the drive-lines, then make another adjustment if necessary.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 08-12-2011, 08:41 PM   #4
texastrendz
well i may have explained the angles wrong, both of the drive shafts are pointing down hill towards the carrier bearing. I don't know if this makes a difference or not?
Old 08-12-2011, 09:54 PM   #5
PBFAB.COM
PBFAB.COM's Avatar
I just assumed the second shaft sloped upwards...
With this new information, it puts your front and rear operating angles at 1*... good to go.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 08-12-2011, 10:09 PM   #6
texastrendz
o.k. now i am getting a little excited, Just so that I know for sure:
Tailshaft is down 6* towards carrier
First shaft out of trans down 5* towards carrier
Second shaft out of carrier up 4* toward rearend
Rear pinion angle is 3* down toward carrier
It is making a "V" shape from trans to rear.
Old 08-14-2011, 01:58 PM   #7
DHPmike
DHPmike's Avatar
The rule of thumb on a 2 piece driveline is 2 degrees of difference MINIMUM between adjoining pieces. You want your trans and rearend within 3 degrees of each other.
DHPmike is offline   Reply With Quote
Old 08-15-2011, 12:34 AM   #8
ItsRandy
ItsRandy's Avatar
Check this out: http://www2.dana.com/pdf/J3311-1-DSSP.pdf. You can print it and it will answer all of your questions.
ItsRandy is offline   Reply With Quote
Old 08-15-2011, 12:45 AM   #9
YBNORML
YBNORML's Avatar
Good info. Thanks
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Thread Tools
Display Modes
