Old 04-08-2003, 12:27 AM   #1
mikep
Used to have a truck
mikep's Avatar
I just crapped my pants!
OK maybe I didnt really crap my pants but I did come close. I just took the '68 out for a full power run with the new gears. Ive been babying it until now because my driveshaft was too short and I was only getting an inch and a half of spline engagement. A few light burnouts here and there but nothing major. I didnt want to rip the splines off the shaft. Anyway I got the right driveshaft for an Eaton from WES and got in in yesterday . I'll tell you what. Those 4.57 gears with thatDetroit locker work Great with that XS 274S cam . I found a secluded spot of road and power braked it up. My converter is a bit undersized so the brakes held the tires but as soon as I let off the brake they let go and I left two strips 50 yards long of rubber before I hit second gear . It pulls HARD all the way up to 100 mph . I'd say its running at mid to low 13 level which is pretty good for a pump gas 350 in a HEAVY truck.
No truck :-(
mikep is offline   Reply With Quote
Old 04-08-2003, 12:32 AM   #2
krazy_texan
krazy_texan's Avatar
sounds fun you havent crapped your pants till you pop a wheelie, i have done it before in my ford falcon, 428 cobra jet, narrowed nine inch, etc... it wasnt a big one but i almost had to change my pants when i got home.
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 04-08-2003, 12:41 AM   #3
mikep
mikep's Avatar
A buddy of mine runs a high 8 second steel bodied small block Nova. How do you get 8 seconds in a steel bodied small block Nova? Well you start with a good chassis and you add large amounts of NITROUS OXIDE !!!! You cant even see the motor under all the direct port injection lines plumbed into the tunnel ram along with the dual fogger plates etc. Anyway he took me for a little run once when he still drove the thing on the street occasionally for street races when he only had an 8-71 with dual nitrous plates . It only ran high 9's at that point. I do believe I did crap my pants.
My dads got a 69 camaro with an 8-71 blown 468. As soon as he's done installing the 4 link hes letting me have it for a few months to do the body work. I intend on crapping my pants again.
No truck :-(
Old 04-08-2003, 12:45 AM   #4
bigjimzlll
bigjimzlll's Avatar
yea...theres nothing like the smell of tire smoke in the morning..I took the ET streets off, and put the 295-15s back on...BIG mistake..a cop pulled me over...I swear I didnt try to light them up..I jumped on at a little to pass a guy..at about 25mph...it down shifted and got completely crossed up...lol..didnt get a ticket..the cop new me from the track..congrats Mike..any plans on a different converter?..im going to a 3500 myself
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 04-08-2003, 12:59 AM   #5
mikep
mikep's Avatar
Thats pretty much why I dont run a automatic kickdown. Never have trusted those things. I have a hard enough time keeping the tires planted in the rain without a kickdown. I'd be all over the place if I had one.
I think I will pick up a 3500 stall converter later this year. The only thing I dont like about the high stall converters is the way they drive on WOT. Its just weird ..WWWAAAAAAAA.....
No truck :-(
Old 04-08-2003, 01:05 AM   #6
bigjimzlll
bigjimzlll's Avatar
I normaly dont run the kickdown..I just hooked it up..my step daughter is going to drive the truck on a pass...and I wanted it to be easy in Drive....I manually shift, and I do not want her to manually shift..lol..thats all I need
Anderson,CA
Old 04-08-2003, 02:47 AM   #7
low 84
low 84's Avatar
sounds like fun. i'm about to run that same cam in my 408, should be pretty mild in the bigger motor, but a torque monster.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 04-08-2003, 03:24 AM   #8
68CST327
mikep, you give me hope for my heavy-@$$ C20
68CST327 is offline   Reply With Quote
Old 04-08-2003, 07:12 AM   #9
mikep
mikep's Avatar
Low 84 -
You'll be surprised just how mild that XS274S really is .
No truck :-(
Old 04-08-2003, 08:41 AM   #10
bigjimzlll
bigjimzlll's Avatar
Mike..My xs268s is pretty lopey..its power range is 3000-6000...its in a 350..whats the power range of the xs274?
Anderson,CA
Old 04-08-2003, 08:50 AM   #11
rage'nrat638
rage'nrat638's Avatar
Thumbs up try a b&m mega shifter
you guys need total controll over your shifting so you can let it rip
just a thought, but it was the best 170.00 i invested in my truck.
it really gives a great feel to driving your truck...nothing like...one hand one the wheel..and one on the shifter.....mark
hay that new cam sounds really great...sounds like it was a good
move on that new drive shaft....i love working on my truck......
rage'nrat638 is offline   Reply With Quote
Old 04-08-2003, 11:17 AM   #12
low 84
low 84's Avatar
you mean like this mark?
'05 1500 Crew Cab
RIP
Old 04-08-2003, 03:41 PM   #13
Low69CST
You guys are making me wanna get my truck on the road. I got a 415 stroker, XE284, Dart iron eagle heads, and a victor jr. Behind that a 700R4, 4.10's with a detroit locker. It runs, but no driveshaft, brakes or windows
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 04-08-2003, 04:36 PM   #14
rage'nrat638
Thumbs up yea
that thing is sweet,,, don't you say so low 84!!!!!!!one on the wheel...one on the shifter......yea baby
Old 04-08-2003, 04:55 PM   #15
crazy longhorn
Fabricate till you "puke"
You need one with a "double H pattern", & 6 gears marked on the knob Im ready to play.......but we got hit with snow & rain:p crazyL (capt clutch!)
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 04-08-2003, 05:57 PM   #16
Fred T
Cantankerous Geezer
Fred T's Avatar
Just crappin your drawers ain't bad. It's when your axxhole has to reach down and grab the seat cushion to hang on that means you've been in trouble. Running 40 on glare ice in a semi in the right lane when an old man going 10-15 in the left lane decided to exit. 60' of truck sideways across a bridge and getting it straight without hitting anything. Left a hole in the seat cushion about 3 inches across.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 04-09-2003, 02:52 AM   #17
bodazpa
bodazpa's Avatar
hey fred t, over here we call that diamond experience(if ya had a peice of coal in your a$$ at the start, you`r a$$ would have been so tight it would have made a diamond).
71 chevy 4x4 ,np205 transfer case, 3 speed tranny, sjs 283, 4in suspension lift, and 71 hugger orange paint,33x12.5 parnelli jones on 15x10 m/t classicII, cowl hood,new bed painted, linex liner. Truck has been completed since 2005....
2003 Chevy Avalanche Z71, on 6in super lift w/ 35in tires
RNG4x4 aka the "Redneck Roller"
words to live by "If it fits, it fits"
"friends help you move, real friends help you move bodies..."
Sponsored by "Kick Ass Kustom"
bodazpa is offline   Reply With Quote
Thread Tools
Display Modes
