Old 08-15-2011, 10:32 PM   #1
funkytechmonkey
funkytechmonkey's Avatar
Break plumbing diffrent with ebreak setup?
I always begin with.... Remember I am a rookie.
I am about to buy all the gas and break line plumbing for my truck and need some advice. The pic below is my setup... I am running the wilwood disc conversion kit with ebreak. Can I purchase a prebent line setup? Is that the best route to go? and last... who do you reccomend me buying a prebent kit from?
Never wrenched a day in my life and now...
Im doing a frame off restoration on a 1968 C10
with a Porterbuilt Dropmember, Acuair E-Level kit,
Boyd Welds Gas tank and mild c-notch.
Click here to view my build
funkytechmonkey is offline   Reply With Quote
Old 08-16-2011, 04:14 AM   #2
stealthy '69
'69 Chevy SWB
stealthy '69's Avatar
Re: Break plumbing diffrent with ebreak setup?
I'm a rookie right there with you. But if it were me, I'd buy a pre-bent line for the rear end like you are asking about, but keep in mind you'll need rubber or flex lines at the calipers to allow for movement. So i'd just cut enough off the ends and add the necessary fitting to install the hoses to the calipers. I'm not sure where to get any of it for sure, but I'm sure others will chime in by morning.
By the way, that is one great looking chassis you're working with. maybe one day I'll have the time, money and space to do a full tear down and rebuild.
Matt
'69 Chevy SWB Fleet, Primer Black; Project No Name
'06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold
'08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!!
'99 Dodge Dakota R/T, Intense Blue; DD, Sold
Originally Posted by longbed67 View Post
The tig welds are not the prettiest i have seen but they do have good penetration.
Originally Posted by oldblue1968chevy View Post
There are two things in life where penetration is really important.....and one of them is welding.
stealthy '69 is offline   Reply With Quote
Old 08-16-2011, 12:20 PM   #3
belowme51
belowme51's Avatar
im going to use braded lines from the calipers to and then make my own lines from there foward... if you go thru Pops dropmember build by superflysteiny he has some great pics on how he did it. with all the PB parts that is the route im going.....you have a much smaller notch and my be able to get away with running a premade rear set. I would ask nate his thoughts.
belowme51 is offline   Reply With Quote
Old 08-16-2011, 12:34 PM   #4
tubbedII
needs more $$$
tubbedII's Avatar
inlinetube.com is a good place to start for pre-bent tube. I don't know if they have a kit for rear discs, but that's who I would contact 1st. I'm not done with my kit install yet, but everything so far has lined up great.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Thread Tools
Display Modes
