Old 04-08-2003, 09:41 PM   #1
Pardue'sCustoms
Pardue'sCustoms's Avatar
cam and crank gears please help
what year did chevy line the dots up on both the cam and crank i thank i have a 1980 motor suffix code tmm casteing # 3970010 and do the dot go up on the crank and cam down or both up thanks
Pardue'sCustoms is offline   Reply With Quote
Old 04-08-2003, 10:00 PM   #2
Chevy67Tk
Chevy67Tk's Avatar
Crank up, cam down so they line up. If you know some one with a degree wheel and dial indicator kit make use of it you would be amazed at how many are off mark a degree or 2 on the factory marks.
Chevy67Tk is offline   Reply With Quote
Old 04-08-2003, 10:10 PM   #3
lngbed71
Nothing fits but the oil
lngbed71's Avatar
Crank up....cam down
Land of the free
Because of the brave
lngbed71 is offline   Reply With Quote
Old 04-08-2003, 10:16 PM   #4
bigjimzlll
bigjimzlll's Avatar
with the crank at 12 oclock and the cam at 6 oclock you will be on number 6 compression stroke...turn the crank one revolution and the crank will be at 12 and so will the cam...now your on the #1 compression stroke....so ...install crank 12 and cam 6...then rotate crank 360 degrres for the distributor install
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Thread Tools
Display Modes
