FightingFire Saving Lives
HELLO ALL.........I PULLED SOME DENTS TODAY ON MY TRUCK. ONE OF MY FELLOW FIREFIGHTERS OWNS A BODY SHOP, HE HAS BEEN DOING IT QUITE A WHILE. I PULLED THE DENTS BY USING THE OLD FASHIONED TOOL(SCREW IN AND PULL TOOL)NOT QUITE SURE WHAT YA CALL IT.
ANYWAYS I FIGURED HE WOULD WELD UP THE HOLES, THEY ARE PRETTY SMALL. BUT HE INSISTED ON USING FILLER. HE STATED THAT WITH THE HOLES THERE FILLER WOULD BE THE BEST CHOICE AS IT WOULD GIVE IT SOMETHING TO HANG ON TO THROUGH THE HOLE. QUESTION IS, DOES THIS SOUND RIGHT? WAS HE BEING ABIT LAZY? I HATE TO SUGGEST THAT, JUST CURIOUS IF I SHOULD STRIP THE FILLER AND GET EM WELDED UP. THE BED IS STRAIGHT NOW, LOOKS GOOD. DENTS WERE PULLED ALL THE WAY OUT AND GROUNDED DOWN TO BARE METAL. WHAT DO YOU GUYS THINK? I HAVE ONLY BEEN USING THIS BOARD FOR ABOUT A MONTH NOW, BUT I HAVE BEEN GIVEN SOME GREAT ADVICE ON HERE, AND BELIEVE IT OR NOT I AM JUST AS INCLINED TO ADHERE TO THE ADVICE OF MY FELLOW CHEVY BRETHERN AS I AM A FELLOW FIREFIGHTER. SORRY FOR SUCH A LONG MESSAGE AND THANKS A MILLION FOR ALL OF YOUR ADVICE. SINCERELY, CHUCK MISENER(TULSA, OKLAHOMA). ![]() ![]() |
![]() Join Date: Aug 2001
in the old days I'd just use filler but anymore I would definetly weld up the holes. I've see the filler crack out little circles to many times - besides if you weld them up right, you just need that much less filler.
Smooth68's Web Site WTB 64-66 project or frame/cab, SWB or LWB...I have the fever! Whatcha got?? '68 Short Step - Shaved Body, Soon Bagged - SOLD Driver-2004 GMC Z-71 Ext-cab |
Definately weld them, if you don't you will probably be doing it sometime in the future. The filler that is exposed on the back of the hole will be subject to moisturewhich can cause rust and body filler failure.
1970 GMC Burb 4x4 - 68 Chevy Front, FI LT1, 4L60E 1970 Chevy Impala 47,000 miles 2001 BMW 540i 6-speed 2002 Dodge Ram 1500 4x4 w/20's |
weld the holes up it keep mosture out and when mositure get behind bonda it cause it to crack later down the road
I would have probably welded them, but I don't believe I would redo it now, if it looks right. Go in behind and seal the backside with some undercoating or something. This should keep the moisture from wicking through the filler and causing rust.
69 SWB LT1/4L60E www.classicplace.com |
ready for reassembly
I tried the lazy way too chuck.....it doesn't pay! it looked good when i did it, but once the moisture got behind the filler, it expanded, and made a round bulge where the hole is. looks like crap!! so now I have to knock the filler out and weld
Jason ![]()
stock 71 4x4 2003 Jeep Liberty, rocky mountain edition I'm obsessed, and wouldn't have it any other way! |
![]() Join Date: Mar 2000
weld em
Saskatoon, Saskatchewan Canada |
[QUOTE]Originally posted by Jason71k10
[B]I tried the lazy way too chuck.....it doesn't pay! it looked good when i did it, but once the moisture got behind the filler, it expanded, and made a round bulge where the hole is. looks like crap!! so now I have to knock the filler out and weld
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
Much nicer welded. Wire welder does great job on projects like this...........
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
1969 Custom 30 wrecker
I agree, weld them shut. I have a body working book I bought years ago that also agree's with your friend though. They even show a pic of the filler squeezed through from the back side and says it gives the filler something to bite to. I bet most body shops would still use that method but I wouldn't. It's a place for moisture to get in and we all know what that does! Bubble city.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
That method has not been the standard in bodyshop repair procedure in over 15 yrs. Yes, it does work for a while but eventually the repair "bondo" will fail and will need to be corrected.Never give your enemy-moisture- a chance to get behind the filler or you'll have problems.If your'e looking for a quick fix-less than 2 years-then leave it, otherwise weld it.
you never have too many suburbans.... |
Seasonal Poster
I'm with Jason, I was lazy and now im paying for it! It sucks, because you get blinded by the immediate beauty of filler...when its on there and covered with primer you think, wow that looks good, what could possibly be wrong with something that smooth. Then 2 year later, you want to kick your own ass for being such a dumbass!!
67 GMC Short Step 350/4-Speed/3.08 Posi Front/Rear Sway Bars Kelowna BC, Canada Member of DTPW |
Thread Tools | |
Display Modes | |
