Old 08-21-2011, 11:32 PM   #1
themb2g
Best Fuel pump for LQ4?
I am putting a 30 Gallon tank from NWFab into a 72 blazer running an LQ4. I wanted to find out what the best fuel pump assembly there is for a daily driver application. I have seen some kits from FAST that were around $320, but I am wondering if i need to go that route. Let me know what you guys think. Thanks!
M
themb2g is offline   Reply With Quote
Old 08-22-2011, 08:42 AM   #2
Shon
Re: Best Fuel pump for LQ4?
Need a 255 pump to keep up with the 58PSI. Doesnt matter if its intank or rail mount. I am using a ebay "E2000" pump on the rail and is works well.
Walbro should have a drop in pump for that tank to fit the GM basket.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 08-23-2011, 09:42 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
im also using a generic 255 pump. Works fine behind my lq4.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-23-2011, 10:14 PM   #4
themb2g
I guess are there any kits that are the best is what I am asking. I am looking for something with SS lines if possible. Pump, filters, tubing, return, etc.
Old 08-24-2011, 01:17 AM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Kit is a bad word. It just ends up meaning that you THINK you have everything, until you actually go to do the job lol. Besides that, prebent fuel lines IMO usually suck.
255 lph pump, decent filter (make sure its safe for FI applications, summit has plenty), plus a few quick disconnects and some FI safe fuel line and your done. If you want to spend a little more, you can get braided lines made up for the supply and return from the engine back to the hard tubing. They are easy enough to assemble in the garage, its not always worth paying for the application specific braided lines.
My fuel system is;
16 gal sumped alum tank -> an to 3/8 FI line->an to pump->255 lph pump->Earls filter->3/8 hard line->hard line to an->an to SS braided->braided to 3/8 quick disconnect-> stock reg assembly-> 5/16 quick disconnect to braided-> SS braided -> an to hard tube-> 5/16 hard tube->return to tank.
Old 08-24-2011, 07:51 AM   #6
Shon
I run rubber EFI hose from tank to filter to pump to vette filter/reg and more EFI rubber hose to fuel rail. simple and "cheap"
Old 08-24-2011, 01:44 PM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I originally did the same, but when I heard about the change in nhra rules about rubber hose, I decided to run braided just in case.,
Old 08-24-2011, 01:45 PM   #8
Shon
Understandable.
Old 08-25-2011, 07:34 AM   #9
CamaroChris
I used this one GS340 100psi Is ment to fit in a tbi sending unit. so I bought it thinking ZI would have to modify a little and sure as poo it fit right in. It even had a wiring conector the plugged into the tbi sending unit. http://www.summitracing.com
I LIKE TRUCKS
1986 GMC Suburban Build Build link
1982 Chevy SWB 2wd Scottsdale, Build Link Sold
1987 Jimmy Build, Project Cheap A$$ Build Link
CamaroChris is offline   Reply With Quote
Old 08-30-2011, 10:50 AM   #10
thepunisher
thepunisher's Avatar
I have the blazer tank installed in my c10. I understand that the fuel pumps prefer to "push" rather then pull the fuel. Will a Walbro or E2000 pump on the frame rail hold up to pulling the fuel from the tank or is it absolutely necessary to install a pump in the tank? It would be a 6.0L LS engine if that matters.
Blayne
thepunisher is offline   Reply With Quote
Old 08-30-2011, 10:52 AM   #11
Shon
mine is pulling from the frame rail and using stock 71 tank.
it runs strong on motor and spray.
Old 08-31-2011, 06:30 PM   #12
eagleuh1
eagleuh1's Avatar
Mines worked for about 5000 miles so far pulling from the frame rail through a prefilter and then out through the Corvette filter regulator. Just a little heads up. Summit sells the Corvette filter regulator for $39 bucks. Wics brand. I just got it with my fittings as well. Good luck. Jim
eagleuh1 is offline   Reply With Quote
Old 08-31-2011, 06:31 PM   #13
eagleuh1
eagleuh1's Avatar
My pumps a Wallbro 255 lpm.
Thread Tools
Display Modes
