Old 08-22-2011, 04:24 PM   #1
oleski2010
electric heater or under dash conversion
I live in eastern nc and it normally doesnt get to cold in the winter. im looking at smoothing out the firewall in my 68 when i convert it to the 396 i found a golf cart heater with an out put of 1300 watts runs on 12v. has an adjustable thermostat and fan control so my question is what do you guys think of just running electric heat its a whole lot cheeper then the under dash conversion kit.
oleski2010 is offline   Reply With Quote
Old 08-22-2011, 09:43 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: electric heater or under dash conversion
I would guess it should be enough.However a Golf Cart has lots of amps(several batteries) to draw from.1300 watts is determined as volts X amps so you will multiply 12 volts X 118 to get 1296 watts.
I doubt your alternator is up to the task.The other thing is that I'm assuming that in your area you really only need defrosters.Ducting may take up a lot of room.If you're planning on AC then most aftermarket AC kits can be ordered with heat/defrost.
Here's an answer http://wiki.answers.com/Q/Formula_for_watts_and_amps
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 08-23-2011, 01:01 AM   #3
mcmlxix
Collector of Projects
mcmlxix's Avatar
www.flex-a-lite.com/auto/html/mojave-heater.html
Rich
1972 K5 Blazer CST Click HERE
Old 08-23-2011, 06:22 PM   #4
oleski2010
that looks like a really nice unit but i wanna clean up under the hood and would like to delete the heater hoses its such a pain to try and make them look neat and clean. and for the electric heater i thought of that a little i was planning on running a diesel battery for the heater and a separate battery for the actual vehicle but i didn't think about the alt. i could always get the 180amp alt. but the alt would be working hard hmmmm.
Thread Tools
Display Modes
