04-09-2003, 09:04 AM | #1 |
Auto to Manual
Hey guys,
I've found a lot in trans. swap info. here. But most of what I find seems to be that members swap a manual 3 or 4 speed to a 5 speed. It seems these trucks already have the manual trans. (high hump) so there is no real problem with the fit. But, I would like to swap a th350 (low hump) to a 5 speed. Is there a lot of carving to do on the hump or firewall to get a manual trans. to fit? What types of trans. do you guys use? How did you finess the shifter location so that it is a good fit on the hump (the shifter doesn't hit or get in the way of anything?) What type of clutch pedal assembly did you use? I'm thinking of fitting a late 60' Camaro or Chevelle assembly in my truck; good idea or not? Just trying to size up my options for a future swap. Trying to save $2,500-$3,000 for this job. Thanks, James |
04-09-2003, 09:34 AM | #2 |
Fabricate till you "puke"
I just swapped a 6 spd Richmond trans in my 69....expensive trans, & wont fit under a low hump floor. I used the stock truck bell, & clutch linkage(rod ends added to make it work a little slicker). I dont know if you plan a daily driver, or like to race a bit.......but the centerforce clutches are very nice. I have a centerforce dual friction clutch set, & a hays billet flywheel, with ARP fasteners. The 3 spd stick trucks had a low hump, & the 4 spd car trannies will fit, as well as some of the aftermarket 5 spds. One of the guys just swapped a Tremmec tr-3550 into his truck, & it was said to fit the low hump floor without mods....they are a nice trans too....... crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
04-09-2003, 10:07 AM | #3 |
I have the clutch assembly including the z-bar if you are in need of it. It is a v-8 assembly.
Let me know Mark
1970 GMC Burb 4x4 - 68 Chevy Front, FI LT1, 4L60E 1970 Chevy Impala 47,000 miles 2001 BMW 540i 6-speed 2002 Dodge Ram 1500 4x4 w/20's |
Thread Tools | |
Display Modes | |
