Old 08-23-2011, 01:58 PM   #1
taylordise
taylordise's Avatar
Booster problems
I need help diagnosing a problem. After leaving my first car show where the truck was sitting in about 90 degree heat all day my breaks stopped working. My uncle and I think it's possible the booster went out. I've been doing some reading at it could also possibly just be a check valve. I will check that when i get home from work. Anyone ever have a similar problem? Any thoughts or suggestions would be great!
Thanks guys!
Taylor
taylordise is offline   Reply With Quote
Old 08-23-2011, 02:17 PM   #2
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
Re: Booster problems
have you tested to see if its the booster ? before starting engine pump your brakes up and hold the pedal ,start the engine does the pedal drops ? or stays in the same place ?
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 08-23-2011, 02:19 PM   #3
taylordise
taylordise's Avatar
Stays in the same place.
Old 08-23-2011, 02:49 PM   #4
68gmsee
Active Member
68gmsee's Avatar
If no downward movement, even slightly, when you start the engine then your assumption that the booster is bad is probably correct.
Be sure and check the vacuum hose and valve to make sure those are working.
68gmsee is offline   Reply With Quote
Thread Tools
Display Modes
