Old 08-31-2011, 10:26 PM   #1
Handfull 54
Handfull 54's Avatar
Clunkung from right front Mustang II front end
My truck has a clunking sound comming from the front end passenger side. I notice it when I release the brakes. It looks like the fender is dropping down at the time of the clunk. Any ideas on where to start? I have 325 miles on it. It has all new bushings,springs and shocks and uses Chevy rotors and brakes on the mustang spindle.
Handfull 54 is offline   Reply With Quote
Old 08-31-2011, 11:27 PM   #2
50adrod
50adrod's Avatar
Re: Clunkung from right front Mustang II front end
if it has strut rods one may be loose, definitley check it out sounds unsafe
1971 Corvette convertible 454@ 525 hp
1936 Chevy Truck street rod
1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up
1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html
1950 custom Chevy Truck
50adrod is offline   Reply With Quote
Old 09-01-2011, 01:33 AM   #3
solidaxel
solidaxel's Avatar
I would NOT drive it until you replaced or tightened the problem>
Place a jack under the shock and take the weight off the wheel and try and move things around, look at all the connections, including the upper shock bolt
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 09-01-2011, 06:26 AM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
Take a look at the disc pads to make sure they are not slopping around in the caliper. The tabs on the outer pad need to be bend tightly against the calipers. You can do it with water pump (channel Lock) pliers
dwcsr is offline   Reply With Quote
Old 09-01-2011, 04:37 PM   #5
Handfull 54
I found the problem. I jacked up the truck and began checking the bolts from top to bottom. I noticed the upper A frame "hat" was shiny from the upper A arm rubbing back and forth on it. I tightened the top bolts which were very loose and worked my way down. I used a torque wrench as some of those bolts need to be tightened to 120 ft. lbs. Anyway I did both sides and got everything tight. I just road tested it and the clunk is GONE. Thanks to all of you who responded, it was good information. And yes the strut rod bolts were loose also. Thanks again.
Old 09-01-2011, 04:46 PM   #6
55dude
55dude's Avatar
i have seen this before and recomend a drop of loc-tite and retorque the bolts to specs.
55dude is offline   Reply With Quote
Old 09-01-2011, 05:53 PM   #7
gearheads78
gearheads78's Avatar
I like to use mechanical lock nuts instead of lock-tite. Lock-tite can melt with the heat the brakes generate.
gearheads78 is offline   Reply With Quote
Old 09-02-2011, 01:17 AM   #8
parkwood
parkwood's Avatar
Hope you plan on getting the front end re-alined... your camber will be off if the top a-arms moved... just saying..
parkwood is offline   Reply With Quote
Old 09-02-2011, 09:33 AM   #9
Handfull 54
Thanks Parkwood. I plan on doing that next week. I found a guy who has an alignment shop and also has a shop at his house. He told me to come over to his house shop where he can spend more time and get everything alined and torqued.
Thread Tools
Display Modes
