Old 09-01-2011, 01:49 PM   #1
pvienneau
pvienneau's Avatar
How to paint the bed wood to original Spec
Now that I purchased the original size Yellow pine boards for my PU how do you guys suggest I paint them. I am planning to paint them Black like the originals.
Pat
pvienneau is offline   Reply With Quote
Old 09-01-2011, 03:22 PM   #2
justplainray
justplainray's Avatar
Re: How to paint the bed wood to original Spec
read these two articles....very imformative
http://www.mar-k.com/wood_finish_testing_i.html
http://www.mar-k.com/wood_finish_testing_ii.html
justplainray
justplainray is offline   Reply With Quote
Old 09-01-2011, 04:33 PM   #3
pvienneau
pvienneau's Avatar
Thanks - I plan to go with the 3 coats of POR-15 rust preventative and 3 coats of of Behr best quality black exterior latex enamel. I'm going with a non gloss look though. I will paint the steel straps with Rustoleum primer and flat black spray paint.
Old 09-01-2011, 11:15 PM   #4
tmoble
factory used oil base varnish with lampblack for color.
tmoble is offline   Reply With Quote
Old 09-01-2011, 11:36 PM   #5
Root2812
Root2812's Avatar
"The Advanced Designed Trucks bed wood came from the factory treated with a combination of linseed oil and lampblack, giving it a dull black color."
From this http://www.gmcpauls.com/47-72_BedWood_Info.htm
Root2812 is offline   Reply With Quote
Old 09-01-2011, 11:41 PM   #6
tmoble
that's where I saw it too, nut I remembered it wrong, a little.
Old 09-01-2011, 11:44 PM   #7
Root2812
Root2812's Avatar
I figured thats what you ment and where you saw it. Its being discussed in another thread right now too.
Old 09-02-2011, 02:50 AM   #8
dicer
I'm not sure what year you have. But as far as task force trucks there was nothing I can think of that was ever painted a "flat" black. There was lots of things painted semi gloss though. There are not many restorations that use the correct semi gloss black, most are lacking enough gloss.
dicer is offline   Reply With Quote
Thread Tools
Display Modes
