Old 09-01-2011, 05:52 PM   #1
NuttinSpecial
NuttinSpecial's Avatar
?'s for guys with bagged trucks
For you guys with trucks on air, how often do you drive it and how often or have you ever had any problems? Would you consider bags dependable? As in would you be comforatable takin it on a 4hr road trip to a show?
Been wantin to bag my 72 but all i ever here is how undependable they are and how many problems they give, but ive also heard that if your setup is done right there as dependable as springs.
Just wanna get some input strait from the mouths of bagged truck owners. Instead of people who only talk bad about them
Thanks for any input.
NuttinSpecial is offline   Reply With Quote
Old 09-01-2011, 06:08 PM   #2
SBTork
Garage wrench
SBTork's Avatar
Re: ?'s for guys with bagged trucks
I am also interested in owners answers to this, even though my mind is already made up towards going with bags.
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 09-01-2011, 06:15 PM   #3
NuttinSpecial
I also started this thread under the other section and its gotten a couple more replies, but same here i pretty much already decided to run bags. Anyways here You go
http://67-72chevytrucks.com/vboard/s...20#post4876620
Old 09-01-2011, 08:27 PM   #4
broey
Square
broey's Avatar
bags are very dependable, If someone tells you otherwise they either have a hack job set up, or are just mad they can't afford it and need an excuse. Every time I see a line brake, it's because it was rubbing on something and not secured properly. If a bag blows(which almost never happens) it was abused. And yeah, compressors fail. But if you hook up a schrader valve to a line running to your tank, you will always have a way to fill up. I Would have no worries when it comes to my air ride during a 4 or 5 hour trip.
Squarebody Syndicate
broey is offline   Reply With Quote
Old 09-01-2011, 08:33 PM   #5
Wscott9689
Wscott9689's Avatar
^^ I agree. if everything is done right it is just as dependable . just do your homework and do it right the first time and you'll be more than satisfied.
Wscott9689 is offline   Reply With Quote
Old 09-01-2011, 08:40 PM   #6
NuttinSpecial
Thanks guys, exaxtly the type of feed back i was hopeing for!
Old 09-01-2011, 09:01 PM   #7
Rochlow
My last truck had air and was driven to the Carlisle all-truck nationals every year, which is 1200 miles round trip. Never once had an issue with the air.
Rochlow is offline   Reply With Quote
Old 09-01-2011, 10:24 PM   #8
Slammed50
I have had a bagged car for a couple years now but it hasnt seen much road time since I am still chopping it and finishing some body mods. My good friend has had his '53 chevy bagged going on ten years and has only had one line leak in that entire time. Very dependable as long as it is set up right, no rubbing or chaffing on any thing and clean perpindicular cuts on the tubbing are a must. Double check all your fittings and make sure your compressor stays clean and your good to go!!
Check out my build thread for my '63:
http://67-72chevytrucks.com/vboard/s...49#post4806049
Slammed50 is offline   Reply With Quote
Old 09-01-2011, 10:47 PM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
A properly installed air suspension is very reliable. If you doubt that, look around you while your driving down the road. See that tractor trailer over there? It probably has air suspension and logs hundreds of thousands of miles with out failure. Not convinced yet? How about that commercial passenger bus, or the high dollar motor home? Many of them have air suspension as well, and also log thousands of miles each year with out failure.
My point is if an air suspension is reliable enough to be used in these applications, it is defiantly reliable enough for the miles you might put on a vehicle. The deciding factor is proper installation. If an air system is designed correctly and installed with out compromise it will be "almost" as reliable as a steel spring.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-01-2011, 11:06 PM   #10
NuttinSpecial
Good points guys, apreciate em all
Old 09-01-2011, 11:20 PM   #11
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
My only issues have been my own fault, like leaving moisture to freeze in the lines when it's parked for the winter at -40, causing a few cracked fittings. I completely redid all my lines last year using AIR BRAKE lines and fittings. They are easy to use and are obviously DOT approved. Using air brake parts also makes it very easy to find a supplier with any fitting or line you want.
I run two compressors, which is a fail safe in case one were to quit. I also installed a shrader valve in case I lost my compressors all together.
1978 C3500 Crewcab (Project)
1979 C2500 Crewcab (Driver/project)
1988 R2500 Crewcab (Driver)
1988 V3500 Crewcab
1988 R2500 Crewcab (Mint, Ex Fire Dept)
1968 Chev Suburban (4x4 conversion) LINK
1970 Chev C20 Suburban (driver/cruiser)LINK
2005 Impala (Incognito vehicle)
2004 Yukon XL Denali (Kid hauler)
1947 Case tractor
Facebook Page(1000's of pictures of GM cars and trucks organized into albums)
YouTube Channel
Mr Pops is offline   Reply With Quote
Old 09-01-2011, 11:40 PM   #12
NuttinSpecial
Whats the shrader valve for?
Old 09-02-2011, 12:12 AM   #13
newagecustom
c10 Chop Artist
newagecustom's Avatar
I don't even know how many trucks i've had on bags, and all of them have laid out on the rockers. I even bagged a then new 2003 F150 for a friend and the test drive was to a show in Fresno,CA from Phx,AZ, 8-9 hour trip each way.
newagecustom is offline   Reply With Quote
Old 09-02-2011, 09:21 AM   #14
Wscott9689
Wscott9689's Avatar
A schrader valve is basically a fitting that allows you to fill up the air system via an air chuck on a standard air tank or compressor. It's much like a valve stem in a tire.
Old 09-02-2011, 06:04 PM   #15
NuttinSpecial
Ohh okay, thats a good idea
Old 09-03-2011, 12:51 AM   #16
chopped68
both my truck and car(65 belair) are bagged and are daily drivers.very dependable.
chopped68 is offline   Reply With Quote
Old 09-03-2011, 01:57 PM   #17
big_al_71
big_al_71's Avatar
Here are two camaros one belongs to my best friend and the other to my brother in law both cars have been bagged for a couple of years and they have had zero issues, the secret is do it right from the beginning just like anything else.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 09-05-2011, 09:01 PM   #18
ENHANCED AIR RIDE
Its as dependable as the quality of parts used, and installation, like most everything else. We all drive bagged vehicles daily no issues. Keiths f150 is 5 years old, Wes old truck 3 years, new truck 1 yr, mine 2 years, Johns '55 5 years. Keiths we did replace bags earlier this year, he has put a lot of miles on it.
ENHANCED AIR RIDE is offline   Reply With Quote
Old 09-05-2011, 09:40 PM   #19
NuttinSpecial
Good info guys id feel alot more comforatable with somethin bagged and i was already set on baggin my truck i was just wonderin if i would doubt it at some point,
Thanks for all your input!
Thread Tools
Display Modes
