Old 09-01-2011, 09:43 PM   #1
gpk1961
1961 C20 Electrical problem
Good evening all!
Last week I was putting my 61' back in my warehouse and I turned a corner into the parking lot and the horn stuck on. I got her inside and pulled the horn plug to stop it. Looked at the horn button on the wheel - it was clean inside with the plastic intact. I left her in the dark and in the morning she would not start..."as dead as Kelsey's nuts!" ...as they used to say. I jumped her and got her running and plugged the horn in -- still stuck on.
Shut her off and disconnected the battery and heard the click of the horn relay. I replaced the horn relay and - yes - the horn is still stuck on and when the battery is disconnected, it (the horn relay) still clicks. (and would drain the battery again).
No other issues..lights, brake lights and directionals all good...guages work as well. I drove her tonight and all was good. I should mention that prior owner installed an after market directional switch (that works well) and I can see some 'custom' wiring into the fuseblock...
ANyone have this happen? What do I chase down next?
gpk1961
gpk1961 is offline   Reply With Quote
Old 09-02-2011, 02:28 AM   #2
Rob1961
Re: 1961 C20 Electrical problem
gpk1961,
I would look for a grounded wire.
Rob1961 is offline   Reply With Quote
Old 09-02-2011, 02:38 AM   #3
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Yeap...
Somewhere from the horn button in column down to the relay there is a direct ground ....
Leave the horn unpluged, and trace wires untill the relay 'unclicks'.
I'm guessing a column problem
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 09-03-2011, 10:02 AM   #4
gpk1961
Thanks - that is the plan! A good reason to take the int apart for paint anyway!
Old 09-03-2011, 09:56 PM   #5
gpk1961
OK - I found it. I also removed lots of un-needed wires and splice-in's from prior owner. He used some type of CB or two way radio with a power antenna so he left much splicing and extra wires. As mentioned prior owner used an after market directional and at some point looks like he bypassed the horn wire (green) and the wire that lights the gear shift display (grey), These wires had gotten in contact with the under dash and since they had become exposed, were grounding out - leaving the horn rely switch "on" and draining the battery. I got her stuck on a test drive and had to get her towed in :-(
But it looks like I found it. Removing all extra wires and properly joining and sheathing every other wire. Now on to getting ready to paint the interior. Thanks for the help. Attached some before and after pictures from today's work!
Thread Tools
Display Modes
