Old 09-09-2011, 11:38 PM   #1
cjohnson6772
cjohnson6772's Avatar
How much does a 2.5/4 drop help handling?
I really want to improve the handling of my truck. I've got a factory front sway bar. I've got an Iroc bar for the rear but after reading in the suspension forum here I don't think I will use it. I've read the camaro bar is too much for the rear and can hurt handling.
So what else can I do to improve to handling? I'm not really big into dropped trucks. I have been considering 2.5/4 drop just to improve to stance a bit and lower the center of gravity. So my question is this: How much will a 2.5/4 drop improve handling and reduce body roll? Will the drop adversely affect ride quality? I am running 275/60R15 tires. Are there any foreseeable issues with this combo? The truck is a '72 shortbed.
cjohnson6772 is offline   Reply With Quote
Old 09-10-2011, 09:01 AM   #2
cdowns
cdowns's Avatar
Re: How much does a 2.5/4 drop help handling?
alot of guys that drop want CHEAPPPPP// you get what you payfor
by replasing the 40yo componennts ,balljoints tyrods bushings as well as rear trailarm bushings as well as shock geometry and quality / there will b a noticable improvement in handeling and driving comfort
i've used the helwig rear swaybar and it worked great, lots of guys have rear problems by going with a too biig bar// rear bar should b no bigger than 3/4the diameter of the frontbar
Old 09-10-2011, 10:25 AM   #3
68gmsee
Active Member
68gmsee's Avatar
As cdowns said...
To add to that, a drop like you mention may help in the roll area but I didn't notice much difference in 2.5 front and 3.5 inch rear drop in my truck. It's going to be trial and error striking a balance between road stability and comfort since these trucks were primarily made for work. A complete workover of the suspension can be pretty expensive.
68gmsee is offline   Reply With Quote
Old 09-10-2011, 11:39 AM   #4
SCOTI
SCOTI's Avatar
The drop in height itself is only going to help so much. Lowering the center-of-gravity makes a difference, but it needs other parts to take full advantage of that lower COG.
Better geometry, better spring rates, shocks designed to compliment, chassis stiffening, modern rubber, & alignment settings to take advantage of everything.
If it's handling you truely seek, I would check into the Hotchkis C10 kit. You get all the benefits mentioned in a well designed & engineered kit. It works & is proven. They list the kit as 4/6 drop but that's most likely w/dropped spindles. Substitute stock spindles & see if they have a slightly taller rear spring choice if you need less drop.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-10-2011, 03:06 PM   #5
cjohnson6772
Thanks to all of you for weighing in on the issue. I've got a couple of questions for each of you though.
CDowns: The stock front bar is 1.125" if I am not mistaken and I think the Camaro rear bar I have is 0.875". This is close to 75%. Do you think it is worthwhile to install the Camaro bar, or should I just stay away from it? I prefer the Camaro bar to aftermarket bars because it is on the axle and up out of the way.
68gmsee: Did you just use drop spindles and drop springs? Did you get drop shocks as well? I am probably looking for 2" drop springs in the front and 4" drop springs in the rear due to budget. Is there anything else I should be looking for as a must have?
SCOTI: I looked at the Hotchkis kit and while it looks like a superb kit I just can't spend anywhere near that amount of money. I'm not looking to race this thing on a track. I am mainly just trying to eliminate body roll under fairly normal (maybe slightly aggressive) driving. Do you think that a moderate drop is enough by itself to appreciate a difference in body roll?
Thanks in advance guys. And feel free to weigh in on any of the questions, not just the ones I directed towards you. I really appreciate the advise. I would love to buy one of the awesome pre-engineered kits, but a college kid's fundage just will not allow it.
Old 09-10-2011, 03:38 PM   #6
SCOTI
SCOTI's Avatar
Lower COG, bump up the spring rates, get some high quality mono-tube gas shocks, & swap to the HD factory 1.25" (3/4 & 1-ton) front sway bar w/poly bushings. Set the front camber @ -.5 ~ -.75° & dial is as much caster as allowed.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-10-2011, 04:24 PM   #7
68gmsee
Active Member
68gmsee's Avatar
Thanks to all of you for weighing in on the issue. I've got a couple of questions for each of you though.....
68gmsee: Did you just use drop spindles and drop springs? Did you get drop shocks as well? I am probably looking for 2" drop springs in the front and 4" drop springs in the rear due to budget. Is there anything else I should be looking for as a must have?.....
In front, dropped springs and in the rear I removed (IIRC) 4 upper leaf springs out of 8 that my truck had. I would go with dropped spindles if I were doing it again. (may still do it)
Old 09-10-2011, 06:50 PM   #8
robnolimit
robnolimit's Avatar
for a 2 1/2" - 4" drop, I'd use a drop spindle in the front with a stock spring. In the back, use a block to get the first 2". then a 2" drop coil, this will help in the ride quality area over a 4" drop spring.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 09-14-2011, 12:16 PM   #9
Hotchkis
SCOTI – Thanks for throwing our name in there! We spent a lot of time making the C-10 truck kit perform awesome!
Cjohnson6772 – You can install our parts separately if there are some parts you feel would get you to your performance goal.
Hotchkis is offline   Reply With Quote
Thread Tools
Display Modes
