Old 09-10-2011, 10:10 PM   #1
muckyp
muckyp's Avatar
Bump stop removal ??
It has become apparent to me that I need to remove the bump stop bracket. What is the best way to get it off? Drill the spot welds, grinder or what?
70 SWB 454/TH400
muckyp is offline   Reply With Quote
Old 09-11-2011, 08:15 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Bump stop removal ??
Electric grinder with a cut-off wheel works great.
Keith
Convert to disc brakes.
Old 09-11-2011, 09:56 AM   #3
SCOTI
SCOTI's Avatar
I remember the bump-stop bracket rivets being in a recessed area on the bracket?? If so, the angle grinder/cut off wheel has to cut the bracket off & then go back & slice the rivets so it can be separated from the frame.
It might be easier to drill these & then separate the bracket from the frame.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-11-2011, 10:09 AM   #4
Slammed50
I pulled mine off a set of '77 arms and they did not have any rivets. They had about six spot welds holding the tower to the lower control arms. I used an 8mm spot weld cutting bit and drilled untill it just started to touch the lower control arm. I use a spot weld seperator but a small cold chisel will work to split it from the arm. Then dress the spots as needed.
Check out my build thread for my '63:
http://67-72chevytrucks.com/vboard/s...49#post4806049
Slammed50 is offline   Reply With Quote
Old 09-11-2011, 11:14 AM   #5
lolife99
lolife99's Avatar
Are we talking bumpstops on the front lower a-arms?
Or on the rear frame rails?
What year truck?
Keith
Old 09-11-2011, 11:39 AM   #6
SCOTI
SCOTI's Avatar
What year truck?
Oops.... Very true as I was thinking rear bump-stop (I call the front one a steering stop).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-11-2011, 04:21 PM   #7
muckyp
muckyp's Avatar
Sorry, I am needingto remove the front brackets on the lower a arm. I think I read somewhere that guys have used an air chisel to remove it. But I'm not sure how to start that process. Do I just start chiseling at an edge. Seems like it might damage the a arm itself.
70 SWB 454/TH400
Old 09-11-2011, 04:25 PM   #8
RUSHNBOBO
All the above then get the big hammer
RUSHNBOBO is offline   Reply With Quote
Old 09-11-2011, 04:40 PM   #9
lolife99
lolife99's Avatar
A sawzall will also cut them off.
I ususally save the steering stop, so the spindle has something to contact,... and remove the rest of the bumpstop bracket.
Keith
Old 09-11-2011, 05:05 PM   #10
muckyp
muckyp's Avatar
Do you happen to have any pics of how you left the steer stop? I was considering that but didn't really see a way to do it still make room for the bag.
70 SWB 454/TH400
Old 09-11-2011, 09:50 PM   #11
lolife99
lolife99's Avatar
Like this.
It could actually be cut down a little more.
This is on a 5.5" static drop truck.
Keith
Old 09-12-2011, 07:37 AM   #12
muckyp
muckyp's Avatar
Thanks for the help, it is done. Although I did not see the pic until I was done, it ended up just about like that.
70 SWB 454/TH400
Thread Tools
Display Modes
