Old 09-14-2011, 01:44 PM   #1
summerj
Help me choose the Correct VIN Plate/ID Plate
Is this the correct Vin Plate for my 1965 short bed fleet side?
If not please show me what Chevorlet installed in the door jam (Or something close as close to original as possible) Mine is missing.
http://cgi.ebay.com/ebaymotors/UNIVE...item5d30054310
I need a vin plate but not sure what or where to buy one?
summerj is offline   Reply With Quote
Old 09-14-2011, 01:54 PM   #2
Indian113
Indian113's Avatar
Re: Help me choose the Correct VIN Plate/ID Plate
Did you read the whole discription? The orginal "data" plate didn't have a vin # !! You should just call the DMV and find out where your frame # should be and see if it matchs. If it does they may or may not put a new Vin tag on your body
Indian113 is offline   Reply With Quote
Old 09-14-2011, 01:54 PM   #3
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: Help me choose the Correct VIN Plate/ID Plate
Where is my 60-66 Chevy or GMC vin number?
http://67-72chevytrucks.com/vboard/s...d.php?t=463671
Vin Number query
http://67-72chevytrucks.com/vboard/s...d.php?t=402078
1960-1966 Chevy/GMC Pickup Truck Specs & Engine/Trans/Axle ID's
http://67-72chevytrucks.com/vboard/s...d.php?t=327764
Historical/This I know/60-66 Model Changes
http://67-72chevytrucks.com/vboard/s...351107&page=10
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 09-14-2011, 02:47 PM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
like said before, your vin plate on your 65 is centered in the door jam on the drivers side, like pictured. the plate your refering to is the GVRW plate on the DS kick panel.
VIN will also be on frame, drivers side right behind the motor mount. well, some of the VIN will be there, last 8 I think.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-14-2011, 03:05 PM   #5
oem4me
Depending on your state laws, you may not want to try anything tricky with a lost VIN. It would probably pay to be up front with the DMV and do as they direct you, or risk a heap of trouble. If you haven't already, go in and ask about it first, and take it from there. my .02
Old 09-17-2011, 10:58 AM   #6
brawley
Easy Does It
brawley's Avatar
Do you need to get a tag or title or something? otherwise you cannot buy a vin tag unless the dmv issues one- this could be a hassel? you could pop one off from a local junkyard and use it if you are trying to get it titled
brawley is offline   Reply With Quote
Old 09-17-2011, 11:45 AM   #7
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
^ I agree with this.
Summerj,
Why not use the VIN on you frame?
66 C20 Service Truck:
Old 09-17-2011, 12:33 PM   #8
tooslo60
tooslo60's Avatar
I know in California you can't use VIN's from a junk yard becuase all junked vehicles are required to have junk slips turned in to the DMV, I don't know if this goes for all states or not, but it's just something to consider.
Andy
tooslo60 is offline   Reply With Quote
Old 09-17-2011, 12:38 PM   #9
LostMy65
LostMy65's Avatar
Good advice.
Oregon Scrap yards and wrecking yards require a title. The VIN off of a wrecking yard vehicle belongs to that vehicle.
Old 09-18-2011, 05:41 PM   #10
Captainfab
60-66 Nut
X2
If the VIN tag on the cab is missing, talk to your local DMV.
No matter which state you live in, it is against the law to switch VIN tags.
Summerj,
Old 09-19-2011, 09:45 AM   #11
summerj
Smile Re: Help me choose the Correct VIN Plate/ID Plate
OK Thanks guys.
Got it all figured out. Found the Vin stamped in the frame near motor mount.
Ordered a new repo GVW id tag that goes in the Drivers side near door jamb.
I now understand that this tag is not infact the "Vin Plate" but a Gross Vehicle Weight plate or Some call it a " ID Tag" It has various Build Info on it that also includes and some had the "Vin # on them.
The VIN # is Stamped into The Frame near drivers side motor mount and that's what the State recognizes/goes by.
Thank You all that were able to help.
Old 09-20-2011, 12:21 AM   #12
jocko
jocko's Avatar
the VIN is also riveted to the driver's side door sill at the top - does yours have that? Do they match? I would submit that the riveted tag takes precedence over the frame one - folks do frame swaps, etc. If you have no VIN tag on the cab, then your frame VIN could be used as proof to get a new VIN tag with DMV's help - if you know (or at least can guess) that the frame and cab have not parted ways at some point.
Thread Tools
Display Modes
