Old 09-15-2011, 09:32 AM   #1
watchn
1 ton cab. same as 1/2 ton?
Hey guys, i have a chance to get a 1950 1 ton chevy truck. So my question is.. The cab and front clip on a 1 ton the same as a 1/2 ton? What would the differences be if there are any. I will be doing the s10 frame swap. Thanks in advance.
watchn is offline   Reply With Quote
Old 09-15-2011, 09:37 AM   #2
mknittle
mknittle's Avatar
Re: 1 ton cab. same as 1/2 ton?
mine is.but if it weren't it would still be cool maybe a bit cooler.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 09-15-2011, 12:14 PM   #3
mr48chev
mr48chev's Avatar
The cabs are the same but depending on how the 1 ton was set up the wheel well openings may be the same or larger.
Old 09-15-2011, 04:40 PM   #4
watchn
So the cab is the same. But the fenders could be a different size.. Can anyone else verify this info?
Old 09-15-2011, 05:36 PM   #5
mknittle
mknittle's Avatar
fender openings are the same up to 1 1/2 ton. the two I checked are the same as my 1/2 ton. one is a 9' bed the other is an old 1 1/2 ton orchard truck. both are in my back yard so I see them everyday.
Mark
My GMC build.
Old 09-15-2011, 08:42 PM   #6
Dan Bowles
AD Addict
The 1 1/2 ton fenders are bigger. They are 4" wider and the hood is different!
1/2 ton to 1 ton are the same sheet metal. I had an ongoing discussion with Old Sub for a while on the opening of the wheels. There may be some difference if they were running 19" rims on the 1 ton. He passed away before we could get together and arm wrestle for it. The truck I had with the bigger openings I'd already sold so I could measure!
Dan Bowles is offline   Reply With Quote
Old 09-16-2011, 10:30 AM   #7
mknittle
mknittle's Avatar
There is also a rumor floating around that the 1 ton front fenders are wider. that is what got me to measuring. too bad it's just a rumor. low and wide would look cool
Mark
My GMC build.
Old 09-16-2011, 10:31 AM   #8
mknittle
mknittle's Avatar
Not this one
Mark
My GMC build.
Old 09-16-2011, 11:53 AM   #9
mknittle
mknittle's Avatar
my mistake it is a 1 ton but a heavy one,
Mark
My GMC build.
Old 09-16-2011, 12:55 PM   #10
Root2812
Root2812's Avatar
Mknittle, Your truck may have had parts swapped so measuring your fenders as a comparison isn't going to be accurate. The picture you showed has the 1 piece windshield and vent windows making it 54+ but the grill laying on the back is 47-53 and corrrect me if I'm wrong those fenders also look 47-53. I think the front grill opening was different.
I'm by no means an expert but I'd say that truck you pictured had the front clip swapped at some point so the fenders you mesured may be 1/2 fenders on the big truck.
Root2812 is offline   Reply With Quote
Old 09-16-2011, 01:57 PM   #11
mylow53
mylow53's Avatar
its got wind wings as well. the 54 would be a one piece door window
GT
Greg
1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school
http://67-72chevytrucks.com/vboard/s...=215079&page=5
mylow53 is offline   Reply With Quote
Old 09-16-2011, 03:51 PM   #12
bretcopsey
There is also a difference in the hood in addition to the fenders-check this thread, post #26
http://67-72chevytrucks.com/vboard/s...=423619&page=2
My 51 project
http://www.cardomain.com/ride/2285825
My 68 Camaro project
http://www.cardomain.com/ride/2277404/1
bretcopsey is offline   Reply With Quote
Old 09-16-2011, 05:50 PM   #13
mknittle
mknittle's Avatar
Yeap it is a 54. out of the 9 we have it is the only one and no bed so it will likely end up a flat bed dually
Mark
My GMC build.
Old 09-16-2011, 11:19 PM   #14
T Hilde
Old Sub He passed away
CRAP! How did I miss that? I'm bummed now.
T Hilde is offline   Reply With Quote
Old 09-17-2011, 11:33 PM   #15
Dan Bowles
AD Addict
GT
No, 54s have wind wings or vent windows as well. They were standard starting in '51 even though '51s had the turn down handles.
The grille opening on the blue fenders is a '54. You can see the curve at the top rather than a square edge. There are also indents for the marker lights from the 54/5S1 grille ends. It's just a heavy 1 ton with the 19 or 20" wheels. Probably a dually looking at the front wheels.
How'd you get to 9? I've only got 6!!
Old 09-17-2011, 11:35 PM   #16
Dan Bowles
AD Addict
January or so. Staph infection, I believe. There were posts on Stovebolt and a few other places. There is a fund up to try to cover expenses somewhere. Sucks that you get sick in a hospital and then they bill you for it.
Old 09-17-2011, 11:37 PM   #17
Dan Bowles
AD Addict
mknittle, you could help me out by measuring your wheel openings, though. I sold my 1 ton a long time ago and that is what we were arguing. I was sure my openings were about 1" bigger radius than my lighter trucks (I've got 1/2, 3/4, and 2 single wheeled 1 tons to go with my 1 1/2 ton). Wow, I guess I'm down to 5 trucks now! I forgot I sold one in May...
Old 09-18-2011, 10:30 AM   #18
mknittle
mknittle's Avatar
They followed me home.
we had 15 6 years ago.
The 54 is in pretty good shape.
Mark
My GMC build.
Old 09-18-2011, 10:32 AM   #19
mknittle
mknittle's Avatar
sure what points do you want me to measure? I will do it this after noon.
Mark
My GMC build.
Old 09-18-2011, 07:44 PM   #20
Dan Bowles
AD Addict
Sorry, been gone. I'm not sure how to do it exactly but I'd like to see if you could run a line from edge to edge at the bottom and then see how high the center of the wheel arc is. I could have sworn my old fenders had about an inch more opening but they are long gone.
Old 09-18-2011, 08:56 PM   #21
mknittle
mknittle's Avatar
That's OK I was too we are setting up for a Bonsai show next weekend.
I put a straight edge from the bottom of the radius in front to the bottom of the radius in the back then measured to to the highest vertical point. I get 16 3/8"
to 16 1/2" on 3 different trucks 1ton 3/4ton and 1/2ton.
Mark
My GMC build.
Old 09-18-2011, 10:49 PM   #22
Dan Bowles
AD Addict
Bonsai trees? Cool. Thanks for the info. I'm out for the week but will check mine next week. I suspect they are the same as your's!
Thread Tools
Display Modes
