Old 09-15-2011, 11:13 PM   #1
bmfm64
bmfm64's Avatar
72 c20 a arm question
So I jacked up the truck and the front passenger side upper a arm moved. Long story short, the two studs or bolts that come through the frame with the shims on them and hold the a arm on are loose. I tried to tighten the nuts but can't get to the back and the stud/bolt spin when I try to tighten the nuts. Any insight on how to fix this? Thanks for any help.
bmfm64 is offline   Reply With Quote
Old 09-16-2011, 12:18 AM   #2
SCOTI
SCOTI's Avatar
Re: 72 c20 a arm question
Your going to have to try harder but they are serviceable & are specifically built to allow access (unless modified @ some point). The alternative is to try & weld the stud in place but it would need to be square & 100% seated to do so which requires accessing it as if you were going to tighten or R&R the stud.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-16-2011, 09:13 AM   #3
bmfm64
bmfm64's Avatar
So is there a head of some sort on the back side? I felt around and all I could feel was a smooth round spot that's why I wasnt sure if it's supposed to be a stud that's pressed in or a bolt of some sort that needs a backer to tighten the front nut. Thanks again for any help.
Old 09-16-2011, 09:33 AM   #4
SCOTI
SCOTI's Avatar
There are access holes in the frame to allow getting to the studs. The studs/bolts are actually splined on the ends & are an interference fit that press into place.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-16-2011, 10:25 AM   #5
bmfm64
bmfm64's Avatar
So do they press in from behind?
Old 09-16-2011, 10:50 AM   #6
SCOTI
SCOTI's Avatar
Correct.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Thread Tools
Display Modes
