Old 09-18-2011, 05:58 PM   #1
losthope
losthope's Avatar
exc. positraction??
i have a 1966 - c15 series truck since mines a long bed ,but the stamping on the axle tube says "HA" which on this page says it should be a c14 series(shortbed)? is the rearend maybe out of a shortbed? and what does (exc. positraction) mean??what does the "EXC." part stand for? and do i have posi???
[/QUOTE]
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 09-18-2011, 09:07 PM   #2
Slow Build
Slow Build's Avatar
Re: exc. positraction??
I think it means HA is 3.73 gears (except positraction) so it's the non-posi.
The 3.73 Posi would be the HF.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 09-18-2011, 10:35 PM   #3
losthope
losthope's Avatar
thats what i was thinking i was just hoping maybe i had one, ill know for sure when its drivable !! Now i know what to look for at pick-n-pull, thanks slowbuild
Timmy D.
Old 09-19-2011, 09:33 AM   #4
63sbssbbw
UCA63
63sbssbbw's Avatar
I read it as HC and HG for the posi units ??
The only difference I could fathom between long and short box rears would be at
the trailing arm mounts,where the pinion angle would be set differently.??
As for IDing the posi.
With wheels off the ground,rotate one wheel,if the other follows suit(same direction)
it's a posi.
if it rotates the opposite direction it's a limited slip
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 09-19-2011, 09:36 AM   #5
Str8axle
Str8axle's Avatar
If you spin one rear wheel by hand, and the other one spins the same direction, you have a posi (or something seriously wrong).
Ray
All my life, I've been told I'm a "Bad Influence"
Str8axle is offline   Reply With Quote
Old 09-19-2011, 09:59 AM   #6
63sbssbbw
UCA63
63sbssbbw's Avatar
that's certainly a possibility too Ray
and hopefully accompanied by unpleasant noises
T
member#7816
'61 GMC in progress
Thread Tools
Display Modes
