lowerd 3/4 ton?????? (8 lugs and all)
as i have stated on other thead i have gotten a 52 gimmy from pops it is 3/4 ton and was wondering if there is such thing as a lowerd 3/4 with 8 lugs
WOULD LOVE TO SEE SOME PIX
Im stright up ESL student........ ![]() 94 s10 4x4 4.3/5speed (dd) 68 lwb GMC 350/4speed 52 5 window GMC I6/4speed 12v (8lugs and long bed) 53 bel air 235 I6/powerglide |
#2 | |
![]() Join Date: Apr 2009
Re: lowerd 3/4 ton?????? (8 lugs and all)
Posted via Mobile Device |
Use blocks up front and axle flip the rear.
Right off I can't think of one on the Hamb that has been dropped.
I think the first question is how much do you want to lower it? You can get quite a bit by running 15 inch rims an lower profile tires. Then a dropped axle in front and either removing some leaves or other mods on the rear. There isn't room to put the axle on top of the springs without a big C notch but you might thing about raising the spring mounts on the frame a few inches. Removing leaves would depend on how big a load you intend to tow or haul in the future. |
#5 | |
AD Addict
Blocks up front is a bad idea. If they give, you are running over your steering ability. There is a reason 4x4 guys don't use blocks in the front.
There isn't much room to flip an axle in the rear but you could pull some of the multitude of springs out in both front and rear. |
You could do an aftermarket IFS from any number of manufacturers, then do wheel adapters to get to 8 on 6.5" pattern. I wouldn't suggest this for heavy chores or towing large loads, but it would be one way of getting low and leaving 8 lugs.
Scott's IFS seems to do made to order stuff, maybe you could have them do an IFS with 3/4 ton spindles off a later truck and bags....then you could be 8 lug and on the ground.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
Thread Tools | |
Display Modes | |
