Old 09-23-2011, 11:27 PM   #1
superwade57
rare engine oil cooler option on CL $50
http://rockford.craigslist.org/pts/2613605363.html
rare option good price found it to be of interest
superwade57 is offline   Reply With Quote
Old 09-23-2011, 11:45 PM   #2
67_SS396
Re: rare engine oil cooler option on CL $50
I didn't know those were rare. I have two, maybe three in the shed.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers
'66 C10 - The new hot rod
'77 3+3 Dually - 12 valve 4wd conversion tow rig project
'28 Ford 2 door sedan street rod
RevLimit Offroad
"Hang on beer, we can do this."
67_SS396 is offline   Reply With Quote
Old 09-23-2011, 11:49 PM   #3
superwade57
Touche maybe their Not rare I assumed I know it was option and I've not seen on and I've seen a lot of these trucks. So call it what You want. I saw a post the other day from a Guy looking for one and couldn't find it again so hopefully he finds this
Old 09-23-2011, 11:58 PM   #4
67_SS396
No biggie, hope that didn't come off as being smart. I have two in the shed and still have one on my CUCV. I figured I would just toss the two spares, but may try listing them to see if someone else can use them.
RevLimit Offroad
Old 09-24-2011, 01:59 AM   #5
cr34t3d_by_d4rkd3n
Open ur lmc magazine. U will see." 454: oil cooler standard on all options" if u dont own and havent studied that mag cover to cover.... Just drive into a tree hahah!! Any one else feel me?
cr34t3d_by_d4rkd3n is offline   Reply With Quote
Old 09-24-2011, 08:12 AM   #6
superwade57
Sorry. I prefer to spend my time in salvage yards and scouting the back roads. So I can true GM pieces not that Chinese re-pop garbage. So IMHO someone who knows the inside of a catalog that well has an all together different dream and idea of a classic car and restoration or resto-mod than me. Don't be lazy put in the foot work and a little extra effort. There's something to be said for driving into a tree...like while staring at someones long lost love hiding in the trees behind their property. Something you cant do from your couch while paging through an LMC catalog with your cheeto stained hands. Any one else feel me? BTW since when is this such a negative site and environment? I'm posting something I thought might be of interest to someone.
Old 09-24-2011, 06:00 PM   #7
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
Don't worry bout that guy. I don't know why his account is suspended but he has been a jerk on a couple of other threads I've read.
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 09-24-2011, 08:00 PM   #8
SCOTI
SCOTI's Avatar
The external oil coolers aren't 'common' as most trucks were small blocks. They were common on big-block trucks. I would caution buying a used set-up..... without knowing the condition of the motor it was pulled from, you risk damaging yours. Case in point: my BBC oil cooler set-up 'looks' new when looking it over but the main bearings caused the crank to seize in place. I'm pretty sure there's lots of little floaters within the tubes of that sucker. The only portion of it I'm re-using is the adapter.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-24-2011, 08:53 PM   #9
str8axle55
All 3 of my small block trucks have them. I think they were ordered that way, maybe a plow prep sort of thing in the Northeast.
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD
84 Chevy K30 CC SRW
55 Chevy 210 2dr post
str8axle55 is offline   Reply With Quote
Old 09-25-2011, 12:30 AM   #10
SCOTI
SCOTI's Avatar
By 'common' I meant standard equipment vs optional. Big blocks were known to run a little hotter so an oil cooler was more common & thus would be standard equipment.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-25-2011, 08:45 PM   #11
qksilver
str8 question, could i get some pix of the setup? I have a 78 blazer that I want to option out further than what it is now. I scrapped a 75 burb that had it on the spid but somebody before me stripped all the good stuff and reinstalled crap?
I called the number but no answer.
Thanks, Steve
qksilver is offline   Reply With Quote
Old 09-25-2011, 09:18 PM   #12
Pyrotechnic
Pyrotechnic's Avatar
Ditto on the cleanliness. I wouldn't run a used one without having the core flushed out by a radiator shop or transmission shop with a cooler flushing setup. Also, take it to place that can do hydraulic hoses and have them install new hoses on it. Those hoses are at least 20+ years old at this point, but may even be 30+ years old depending on what year truck it came on.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 09-25-2011, 11:42 PM   #13
67_SS396
The three I have look just like what's in the ad listed above, except mine all went to the radiator and not a separate, stand alone cooler. I can get you some close ups of the sandwich adapter if that's what you're looking for.
RevLimit Offroad
Old 09-25-2011, 11:46 PM   #14
overloaded
overloaded's Avatar
Is there a reasonably priced new/aftermarket alternative to the factory setup?
I see transdapt has a sandwich adapter. Is the core any different from a transmission cooler?
overloaded is offline   Reply With Quote
Old 09-25-2011, 11:51 PM   #15
SCOTI
SCOTI's Avatar
I've wondered about this myself.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-25-2011, 11:58 PM   #16
overloaded
overloaded's Avatar
Summit Racing has a Flexalite Kit #3952 for 83.95 with lines, core and adapter. http://www.summitracing.com/parts/FLX-3952/
Old 09-27-2011, 09:15 PM   #17
qksilver
I was able to get ahold of the guy selling the oil cooler. He also had a couple of other options I needed for my blazer, so good score.
I will have a friend who owns a trans shop flush it and another local guy can replace the hoses with ac/delco repo hoses.
I got the A/T, Engine and power steering coolers complete with all bolts, brackets etc except for 2 gaskets, GM still services those.
Steve
Old 09-28-2011, 08:28 AM   #18
superwade57
I think that you were the 1 that I had in mind when I saw this ad. I couldnt remember your name but the blazer ring a bell
Old 09-28-2011, 08:42 AM   #19
overloaded
overloaded's Avatar
good score. Can you post some pics of the installation when it's done?
Old 09-28-2011, 09:41 PM   #20
qksilver
sure.........should be here next Tuesday.
Steve
Old 09-28-2011, 11:16 PM   #21
overloaded
overloaded's Avatar
Wait, you actually got someone to ship you something from CL?
Everyone I try to buy from is paranoid of scams, or trying to live off the grid without a bank or paypal account (despite the fact they're posting things on the internet?!)
Old 09-29-2011, 09:43 PM   #22
qksilver
I was surprised too, I pay paled tonight so we shall see.........
Steve
Thread Tools
Display Modes
