09-26-2011, 12:33 AM | #1 |
Drop coil spring
So let's put it out there once and for ALL...... 3in drop springs. Is it just the brand or is all 3in drop spring have a hard ride... I have read may things on here, just won't to catch it all on one thread..... So guys how do you feel about these 3in springs
09-26-2011, 07:42 AM | #2 |
67-72 parts collector,…
Re: Drop coil spring
I have Summit Brand (Ground Force) 3" drop springs in my '69 swb.
I like them just fine. Also, only $89.95 per set.
09-26-2011, 11:28 AM | #3 |
Junior Member
Do they have them in a 2" drop? I have not seen them in the catalog. They may be the way to go fir spindles and springs.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
09-26-2011, 11:53 AM | #4 |
You have to search for 73-87 springs.
But they are the same as 67-72. 3" drop: ($89.95) http://www.summitracing.com/parts/SU...n/?prefilter=0 2" drop" ($125.95) http://www.summitracing.com/parts/SU...n/?prefilter=1
09-26-2011, 11:58 AM | #5 | |
Junior Member
09-26-2011, 02:15 PM | #6 |
Lolife99, how low is your crossmember and lower arm........ size tire/wheels
Would like to. 3 more in |
09-26-2011, 02:17 PM | #7 | |
I have 2.5" drop spindles. 3" drop springs. 215/70-15 tire on a 15x7 wheel. Do you want a measurement from the ground? It is low.
09-26-2011, 02:56 PM | #8 |
From the ground...
09-26-2011, 03:52 PM | #9 |
09-26-2011, 06:51 PM | #10 |
The lowest point (of the lower a-arm) is 2.5" off the ground.
09-26-2011, 09:23 PM | #11 |
O' that is to low.... the way these roads are around here, I would have ****ed something up... unless I gey bigger rims later to pick it back up a bit...
09-27-2011, 07:03 AM | #12 |
That's the problem with the trucks.
The lower a-arms hang down too far. The frame has plenty of clearance. That's why the Dropmember works so great. You gain about 3" of ground clearance. My a-arms already have a little paint rubbed off.
10-08-2011, 08:37 AM | #13 |
2 more in. I've got one spring that is cock eyed have been told that itwill seat itself..but I don't like it... May go get spring compressor again..
So 4.5 front 5or6 in rear |
Thread Tools | |
Display Modes | |
