Old 09-26-2011, 07:25 PM   #1
longbed67
longbed67's Avatar
Sandblast or POR15
So here is my predicament I just degreased and powerwashed my framerail today and turns out what I thought was surface rust was just grime and 85% of the rail is still covered in the factory paint. The other 15% not covered I either power-washed off when I got to close or is light surface rust and could be hand-sanded off. SO.... I already own the equipment and material to sandblast the entire frame and I already have POR-15, Do I take the time and blast the frame and take off the factory paint and start from bare metal and then POR-15 it, or do I just sand the factory paint to scuff it up and sand off any of the remaining rust and POR 15 the frame? Any thoughts or other ideas. On a side note it is not in my budget to pay someone to powder coat the frame as nice as that would look...
longbed67 is offline   Reply With Quote
Old 09-26-2011, 08:06 PM   #2
darkone
Re: Sandblast or POR15
how bout hitting major problem areas only with the sandblast and then scuffing the rest? sandblasting the whole thing is a biotch, trust me, i know. ive done it. at least with the cab on it is..... in the snow.... with an underpowered 13horse compressor, and a ****ty eastwood sand pod. good luck suckuh!
darkone is offline   Reply With Quote
Old 09-26-2011, 09:03 PM   #3
slikside
slikside's Avatar
I have never used used POR-15, but have read several threads here from guys who have...what I remember:
You must follow the directions...EXACTLY in order for it to perform.
Part of that (I believe) is applying it to bare metal. So if you want to use it, you should blast the whole thing. And since you already have everything you need, maybe you should just go for it...blast it all, then POR.
Alternatively, you could just scuff up the factory, blast/sand the surface rust, and then just prime/paint the frame. I,e. not use the POR.
I'm sure others with experience will chime in.....good luck.
slikside is offline   Reply With Quote
Old 09-26-2011, 09:13 PM   #4
turp mcspray
turp mcspray's Avatar
As they say..."anything worth doing, is worth doing right!" If you are going through the trouble of a frame off, blast it to bare metal, and then do the POR. If you don't remember anything else anyone tells you, remember this...when your truck is finished, you will never say "I wish I would of half-assed it together."
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 09-26-2011, 09:17 PM   #5
dfwright
dfwright's Avatar
Count my vote for blasting the entire frame and then go with the POR-15. I don't think you'll regret giving it the works later.
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 09-26-2011, 10:57 PM   #6
Ryan5O
I just went through a quart of POR 15 over the weekend. Goes on real easy with a brush. If the body is still on the frame (like mine) wear gloves and long sleeves. The directions arent kidding when it says that if you get any on your skin and it dries, you will be wearing it for a few days. It made going to work the next day kinda interesting.
USCG "Support Search & Rescue, Get Lost"
Ryan5O is offline   Reply With Quote
Old 09-26-2011, 11:26 PM   #7
Willys47
Willys47's Avatar
isn't por15 paint over rust paint. Why not use a paint that is for bare metal? will the por hold to baer metal good? or dose it need rust to bond right
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 09-26-2011, 11:33 PM   #8
jocko
jocko's Avatar
por 15 will work on bare metal - but you highlight a great question - IF you sand blast the rust, then POR 15 really shouldn't be necessary - you can simply apply chassis paint. On the other hand, POR 15 will probably last longer. Kinda like FOREVER, so not sure that is always a good thing. But either way - agree with the folks that recommend blasting first. I would not think POR 15 would work very well over scuffed paint. My 2c.
Old 09-27-2011, 12:03 AM   #9
Ryan5O
When I ran across some spots with paint, the POR 15 wouldnt adhere to it all.
Old 09-27-2011, 01:45 AM   #10
1972hays
1972hays's Avatar
both
72 chevrolet 4wd 350/350 swb fleet green mean army machine
1972hays is offline   Reply With Quote
Old 09-27-2011, 07:53 AM   #11
OJ1988
Just a car guy
OJ1988's Avatar
When painting non rusted metel with por15, you must first use there etching wipe.
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
Old 09-27-2011, 08:42 AM   #12
cdowns
cdowns's Avatar
dont use POR15 on painted surfaces it will not go on good or last goodly
Old 09-27-2011, 10:58 AM   #13
leddzepp
Moderator
leddzepp's Avatar
correct.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 09-27-2011, 02:00 PM   #14
longbed67
longbed67's Avatar
Looks like I will be pulling the motor and trans and all the lines off on thursday night and Blasting on Friday! Which leaves Sat. to Paint! Thanks for all the input!
Old 09-27-2011, 07:45 PM   #15
dfleming7
Smile Re: Sandblast or POR15
I sandblasted the rusty areas and then put the acid on. POR15 on the entire frame. It came out pretty nicely.
dfleming7 is offline   Reply With Quote
Old 09-27-2011, 09:05 PM   #16
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I had mine sandblasted, then we painted it with some black low-gloss paint from Tractor Supply, with a hardener added. I feel good about it.
Member Nr. 2770
Old 10-10-2011, 12:39 AM   #17
1972hays
1972hays's Avatar
Cool Re: Sandblast or POR15
i hate to do this but we need frame pics
Old 10-10-2011, 02:59 AM   #18
808_67C10
808_67C10's Avatar
Wire brush.. Soak with kbs clean and kbs it! It's a lot easier and cheaper than por15.... Imho - holds up just as good! I have used both but like the kbs better
Frank (Hilo, Hawaii)
Trucks, Tacos, and Beer go together like Peanut Butter and Ladies!
85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383
67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298
79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461
808_67C10 is offline   Reply With Quote
Old 10-10-2011, 03:05 AM   #19
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
anytime you can sandblast and take it down and repaint the frame. powdercoated it too
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 10-10-2011, 08:25 AM   #20
Street Smart
Street Smart's Avatar
Sorry for the rookie question, but whats "kbs".
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile*
1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig.
http://67-72chevytrucks.com/gallery/...=74049&cat=500
Street Smart is offline   Reply With Quote
Old 10-10-2011, 10:22 AM   #21
fishingjred73
fishingjred73's Avatar
http://www.kbs-coatings.com/rustseal.html
James
'68 Stepside (ground up in progress)
My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html
'81 SWB "Pap paw" (Driver)
The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html
Member of
www.louisianaclassictruckclub.com
https://www.facebook.com/groups/296290610747732/
fishingjred73 is offline   Reply With Quote
Old 10-10-2011, 10:32 AM   #22
turp mcspray
Por and its variants, are whats called "moisture cured urethane". They work excellent over sandblasted surfaces. They require a rough surface to properly adhere. Yes POR stands for "paint over rust" but when you apply the metal etch, that product is left on the surface for the por to stick to. It isn't actually touching the rust. The name is a little misleading.
Moisture cured urethanes have been around for a very long time. Originally designed for bridges, water pipes etc, that would spend their lives subject to an extreme enviornments. Someone came up with the idea to market them to the automotive market, and the rest is history, as they say.
Turp Mcspray
Old 10-10-2011, 11:35 AM   #23
JON70CST
JON70CST's Avatar
When I built my 68, I sandblasted the complete frame, and then applied POR 15. That is what I would recommend as it worked great! and I guarantee would last for a very very long time. It can be a bit of a pain sandblasting the whole frame if you don't have the right equipment, but if you can get your hands on it, and take the time to do it it'll more than pay off in the long run. Just my two cents
JON70CST is offline   Reply With Quote
Old 10-10-2011, 01:02 PM   #24
Street Smart
Originally Posted by fishingjred73 View Post
Thanks!
Old 10-10-2011, 03:45 PM   #25
longbed67
longbed67's Avatar
Here is the framerail before blasting... I have started blasting but have not finished... I will post photos after blasting...and after POR 15
Thread Tools
Display Modes
