Old 09-27-2011, 04:29 PM   #1
forestb
forestb's Avatar
cut off sitch
where is the best place to wire a security cut off switch? (not a emergency cut off switch)
forestb is offline   Reply With Quote
Old 09-27-2011, 04:39 PM   #2
Scot_Douglas
Scot_Douglas's Avatar
Re: cut off sitch
Between the ignition to the coil and another between the starter solenoid and ignition. If your fuel pump is electric - that supply too.
Then get creative with your switch placement / hiding / masking. (keeping in mind that if someone wants your truck bad enough, it's gone)
1964 C10 - sold to chris1044
1966 C10
Build 'Fread
Scot_Douglas is offline   Reply With Quote
Old 09-27-2011, 06:29 PM   #3
k1rodeoboater
Re: cut off sitch
The coolest one I've ever seen was hidden behind a tail light in a fleetside bed.
1966 C10 Long step build on a budget http://67-72chevytrucks.com/vboard/s...d.php?t=445201
no garage, no shop, limited storage space and tools....no problem.
k1rodeoboater is offline   Reply With Quote
Old 09-27-2011, 10:05 PM   #4
str8axle55
Re: cut off sitch
A friend of mine used to have a stick on digital clock on his dash, the kind that slid into a litle plastic bracket. You had to slide the clock up in the bracket, and there was a small hole you had to stick a drill bit through to push the button. He usd to keep a 1/8 in drill bit in the ashtray. The switch was wired to a RV type fuel selector valve, one side was cut into the fuel line, the other sucked air, through a cheapo plastic VW type fuel filter.
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD
84 Chevy K30 CC SRW
55 Chevy 210 2dr post
str8axle55 is offline   Reply With Quote
Old 09-27-2011, 10:12 PM   #5
krayzog
krayzog's Avatar
Re: cut off sitch
That sounds like a handfull. I just have a toggle switch hidden under the dash, by the steering column. Kind of unnecessary though, even I can't get my truck to start half the time.
1961 Apache 10 SWB
krayzog is offline   Reply With Quote
Thread Tools
Display Modes
