Old 04-13-2003, 02:44 PM   #1
dion
72 Cheyenne
dion's Avatar
How accurate is the Desktop Dyno?
Within 20 HP/TRK?
Burnout
Idle
1972Cheyenne
1966/67Stouts
dion is offline   Reply With Quote
Old 04-13-2003, 05:55 PM   #2
Dean23
68cst_ss490
Dean23's Avatar
i've heard it is within 4 % either way
Dean
edmonton,canada
a winter wonderland
2005 Chevrolet Avalanche LT
cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers.
http://www.cardomain.com/ride/3090973
Dean23 is offline   Reply With Quote
Old 04-13-2003, 06:53 PM   #3
bigjimzlll
bigjimzlll's Avatar
man thats a loaded question....I have found the torque curve is usually much higher in the rpm range than DD2000. If you enter all the parameters correctly(head flow,valve size,cam and cam timing) you can get pretty close. Usually on the high side. The real purpose of the program, is to compare different parts, to see which work best together. My engine on DD2000 shows right at 400HP and 420ftlbs of torque..in reallity its 365HP and 400ftlbs of torque. To be fair, with some more tuning, I might be able to reach the 400HP.
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 04-13-2003, 07:55 PM   #4
beau396
Hotrod mag rated it 3 out of 5, 5 being an engine dyno. You can get pretty close if you know the exact flow numbers to put in otherwise it is almost always spits out pretty "optimistic" numbers. On the other hand a chassis dyno is only a little better for accuracy.
'67 C10 short box fleet side wood bed small rear window frame off restoration. 396BB,Th400, ps, pwr disc 5 lug, posi 3.07, 2000 Suburban 60/40 pwr seats, 2.5" front drop 4" rear, powder coated running gear.
beau396 is offline   Reply With Quote
Thread Tools
Display Modes
