Resurrecting/building a gauge cluster.
I've gotten my tach/small fuel gauge white-faced gauge cluster back a couple months ago, and tonight I started doing some digging. I mean, I have four gauge clusters sitting around, so why not?
This is what was left of the cluster I built when I was 17 was given back to me. I scrapped the Blazer and gave my friend the cluster. ![]() Here's what the fuel gauge and tach actually are. ![]() I've gotten an electronic speedo, which I will FIND a way to make it work with my SM465/NP208 setup. Something GM FWD might have something that works. luckily my Blazer is TBI. I've even thrown in the 1990's light inserts, so just the lettering lights up rather than the whole insert. I had to swap out the copper thing on the back because it was shorted out at some point. I have another two, thankfully ![]() ![]() This is with my fuel gauge jumper wire [piece of an N64 controller wire] ![]() Hopes and dreams... the white paper was just for humor ![]() ![]() More pics to come as I progress, and hopefully find a rig to make that speedometer work. OH, ALMOST FORGOT. Anyone know of any vehicles that they make white gauge inserts like I used, but something that has an 8,000RPM tach? Doesn't have to be specific, as long as it somewhat matches the square gauges.
1991 Mustang GT Vert, T-5 w/ Pro 5.0, Trick Flow upper & lower, BBK cold air intake, 3:73, BAMA chip, etc. 1988 K5 Blazer, [coming soon] TBI 400, SM465/NP208, 12 bolt rear, 3:08's, looks like a 1980. 1998 Jeep Grand Cherokee 4.0 fully loaded daily driver! Where there's a will, there's a rig! |
Re: Resurrecting/building a gauge cluster.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
How are you able to remove the needles and reatatch and still read correct?
John 82 Chevy Silverado 350ci/TH350 ![]() |
HAHAHHA I like your RPM Gauge, that's original!!
-Samuel "Knowledge Is Power" |
Thanks B454, I'll dig through here for a tach insert.
#6 | |
The tach, I had to make a gauge using the center from the old SunPro tach and drilling a hole through the large fuel gauge needle. The tach always reverts itsself back to 0.
The bad thing is I drew it wrong, I need one that goes 0-8, not 0-7
![]() Join Date: May 2009
I know some guys were using a 3rd Gen Camaro tach, and making them work. I don`t know what the redline is, but you can prob get white faces for those. The font is similar but not exact. Did you try doing a search on here for tach info? I think I saw the camaro set up on here.
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD 84 Chevy K30 CC SRW 55 Chevy 210 2dr post |
Thread Tools | |
Display Modes | |
