Old 10-01-2011, 09:10 PM   #1
jocko
jocko's Avatar
hmmm. Noisy clicking speedo after trans swap, any ideas?
Finally got the brakes done after taker several brake fluid showers with a power bleeder (which is now in the garbage) and got the truck back on the road after the t5 swap. Now that I installed the new speedo gear housing (with seal this time...) and the new 20" cable extension - I've got that annoying speedometer clicking noise that goes up and down relative to speed. I know these things can be picky to positioning, etc, but it wasn't making the noise before. Any ideas before I jsut disconnect the thing - it's "that" loud...? Thanks gents.
Old 10-02-2011, 03:02 AM   #2
Rich 5150 69
Rich 5150 69's Avatar
Re: hmmm. Noisy clicking speedo after trans swap, any ideas?
Jocko I `m assuming you only disconnected the trans end...? if there is a bend in the cable will cause that or the able it self is going dry which will cause it to stick then jump forward, try loosening it a little or remove from trans and use some light oil in the cable end, not dw-40 as it is a cutting oil...if all else fails remove whole thing soak really well with light oil and hang vertically in your garage for a few days.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 10-02-2011, 03:19 PM   #3
PAPA KENT
PAPA KENT's Avatar
Originally Posted by rich 5150 69 View Post
jocko i `m assuming you only disconnected the trans end...? If there is a bend in the cable will cause that or the able it self is going dry which will cause it to stick then jump forward, try loosening it a little or remove from trans and use some light oil in the cable end, not dw-40 as it is a cutting oil...if all else fails remove whole thing soak really well with light oil and hang vertically in your garage for a few days.
i agree,it sounds like a bend that is to tight.
Good luck!
PAPA KENT is offline   Reply With Quote
Old 10-02-2011, 11:07 PM   #4
jocko
jocko's Avatar
I think you all nailed it - the only speedo cable extensions I could find were 6" (too short) and 20" (apparently too long....) I bought the 20" version - and although it is a gentle swoop into the trans - it is more abrupt than the speedo cable into the orignal 3-speed, and this is what I was afraid might happen - but thought it was worth giving the 20" (and cheap) cable extension a whirl before I yank the whole thing and try to find a more appropriate lenght single cable - need one about 10" longer than stock - but I don't know how long the stock one is til I pull it out. I really love working under the dash... Maybe it's time to stick that vac gauge in the cluster while I'm at it!
Thanks guys, you've confirmed what I figured I was gonna have to do.
Thread Tools
Display Modes
