Old 10-04-2011, 02:27 PM   #1
matts86chev
matts86chev's Avatar
Sudden hesitation and rough idle?
I have an 86 chevy c10 with a new drivetrain, well it was new last spring so it has about 20k on it now but all the sudden lately it has started idling really rough when I start it cold and takes a few minutes to sound normal. If I don't wait long enough sometimes it stalls as soon as I shift into gear. It also has been hesitating for the first few miles when I accelerate. I'm not sure if I just need to run Seafoam through it or what! Any suggestions?
1986 Chevy C10 305 5.0L Work in progress...
matts86chev is offline   Reply With Quote
Old 10-04-2011, 04:24 PM   #2
Your41Plague12
Your41Plague12's Avatar
Re: Sudden hesitation and rough idle?
Play with the choke, seems like that could be a part of it. Electric or manual choke? If it's electric it might not be functioning properly.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 10-04-2011, 05:48 PM   #3
jasonroman
jasonroman's Avatar
how exactley do you play with electric choke? not sure what its called but a part on mine is sticking. so when i turn on truck, it stays idling high. no kickdown. so for now, i zip tied it...
jasonroman is offline   Reply With Quote
Old 10-04-2011, 08:55 PM   #4
Your41Plague12
I'm not sure how exactly to play with it, but when mine broke I just replaced the electric choke module. It cost about $30 and it solved my problem. What carb are you running?
Steve
Old 10-04-2011, 09:32 PM   #5
rwhit57
rwhit57's Avatar
Sure it could be the choke, but it also sounds like a vacuum leak. Check the intake bolts, carb bolts, all vacuum lines, etc. That's what I'm guessin.
rwhit57 is offline   Reply With Quote
Old 10-04-2011, 10:50 PM   #6
matts86chev
It stops doing it after it has been running a few minutes. I ran Seafoam through it today and that stuff made a world of difference even just in the idle, also changed the oil after running the Seafoam through and spotted some wetness underneath so now another thing to try to figure out! Rough few weeks for my truck.
Old 10-04-2011, 11:00 PM   #7
rayfinseats
Find out what DOES work properly and you'll figure out what doesn't work properly.
rayfinseats is offline   Reply With Quote
Thread Tools
Display Modes
