10-06-2011, 06:17 PM | #1 |
widest wheel and spacing
okay here goes
i have a 68 c20 that i am converting to 1/2 ton. found an 85 chevy for the suspension and rear end. i plan on a 4" drop in the rear and something to match in the front what is the widest rim and what backspacing do i need? |
10-06-2011, 08:29 PM | #2 | |
Re: widest wheel and spacing
This is very subjective too.... What is 'right' for one guy may not be for another. I suggest you get your drop done & take measurements using the wheels available to determine what will/won't work.
10-06-2011, 09:06 PM | #3 |
also, when you start maximizing sizes, tire selection will also matter.
tubbed rear? front wheel wells? leaf spring rear? Lots of questions |
10-06-2011, 09:20 PM | #4 |
Check out the "Percy's Wheelrite" tool. You can buy them at Summit. The best $69 I have spent in a while. It will get you really, really close to perfect wheel spacing / tire size, and the true fit that you want your truck to have. It will do 15-20" wheels .. so completely your call.
Another thing to consider is the overall width of the 85 rear end vs. the original 67-mid 69 (55.5") and 70+ (57") plate to plate. Ex. If someone told you a 20x10 with 5" BS would work on a typical short fleet, your rear axle might be longer / shorter overall and throw it off by 1" or more. I'm not sure how long the 85 model rear end is though. Seriously .. buy the wheelrite. You'll be glad you did.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
Thread Tools | |
Display Modes | |
