Old 10-08-2011, 11:37 PM   #1
Robznob11
Robznob11's Avatar
bump stops
Alright guys. I yanked my control arms and spidlest to day to paint them up and I relized that I never did anything to the bump stops. I have 71-72 arms and am running 3" drop springs and 2.5" spindles. anyone else out there running these (I know there are) if so did you modify yours or replace them with after market. does the bottom bs mounting bracket on the control arm need reworked. or is every thing peachy with the stock set up I don't plan on 4 wheeling but I don't want spine jerking every pot hole eather. I also don't know if they keep things from binding and if you shorten them will that caus bad effects if something were to bind while you were turning
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 10-09-2011, 12:04 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: bump stops
I trim the bump stop mount off and leave just enough of the "steering stop" to contact the spindle with the wheels turned.
Keith
Convert to disc brakes.
Old 10-11-2011, 11:57 AM   #3
crazy longhorn
Fabricate till you "puke"
Re: bump stops
I did the same thing on mine. Also, I drilled a hole in the lower arms & added a traction bar snubber(rubber), as a new bumpstop. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Thread Tools
Display Modes
