10-10-2011, 06:31 PM | #1 |
ac recharge question on retrofit
Want to recharge my ac tomorrow but don't know if its been retrofitted for the r134. Is there anyway to visually look and tell
Posted via Mobile Device |
10-10-2011, 08:01 PM | #2 |
Re: ac recharge question on retrofit
There should be an adapter screwed onto the fill port.
10-10-2011, 10:12 PM | #3 |
Not everyone will agree with this but I've been doing it for years. You can run 134 in an old system without changing anything. It won't get as cold as the R12 but it works fine. R134 is readily avail at the parts stores, you might shoot a can of oil-charge in it.
10-10-2011, 10:17 PM | #4 |
most retro i do i pull r-12 vacumm it for 45 mins put the 134 adapters on (r-12 look like the vavle ona tire with treads) and shoot a can ester oil charge in tot the system and charge it never had any issuses
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
10-10-2011, 10:17 PM | #5 |
Yeah, look for the adapters on the charge ports. No need to change oils or o-rings if it hasn't been retrofitted.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
10-10-2011, 10:33 PM | #6 |
Mainly look for adapters like everyone else said, but really you can put 134a right into an R-12 system without evacuating it.
My system was so empty it didn't even make a sound when I opened the schrader valves, and had to hard-wire the compressor to make it start pushing freon until it started pulling on its own. No matter what refrigerant, it will run constantly except when you're using the defrost or in some instances, depending on the compressor, when the fan is turned down. As for how cold it is, it's not the greatest at low speeds, but when you're constantly moving above 30 it'll freeze your foot off. I recommend putting a can of oil/stop-leak in it too, just in case.
1991 Mustang GT Vert, T-5 w/ Pro 5.0, Trick Flow upper & lower, BBK cold air intake, 3:73, BAMA chip, etc. 1988 K5 Blazer, [coming soon] TBI 400, SM465/NP208, 12 bolt rear, 3:08's, looks like a 1980. 1998 Jeep Grand Cherokee 4.0 fully loaded daily driver! Where there's a will, there's a rig! |
Thread Tools | |
Display Modes | |
