Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 10-11-2011, 12:50 PM   #1
dougminton
dougminton's Avatar
BBC timing question
I've got a .030 over 454 with 10:1 compression and a .615 lift cam.
What do I need as far as timing?
I'm running 91 pump gas and I'm conserned about not hearing detonation.
Currently have 18 initial 38 total, all in by 3000RPM.
The TEAL GMC build thread is HERE
1972 GMC SWB
454 oval ports
TH400
fastest 1/4 mile time so far
13.05 @ 104
If you think you have too much horsepower
you obviously have a traction problem !
dougminton is offline   Reply With Quote
Old 10-11-2011, 03:01 PM   #2
PGSigns
PGSigns's Avatar
Re: BBC timing question
Can not see why you would need more than 36 degrees total.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-19-2012, 09:16 PM   #3
68 TT
Still plays with trucks
68 TT's Avatar
The big blocks I have run on the dyno all liked 34 degrees of timing the best. I would start there and see how it does.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 01-24-2012, 12:54 AM   #4
Handfull 54
Handfull 54's Avatar
I have 20 degrees initial and 16 in the distributor all in by 3000. I use an 850 carb and a Crane solid roller with .636 lift. Big block Chevy 489 cubic inches with Brodix heads. I also agree with 68TT. After all he has run some engines on a dyno and most of us have not. Running 20 degrees advance also solved my cooling problem. With 12 degrees advanced it ran 220 now it runs 180 all day long. I also run 10:1 compression.
Handfull 54 is offline   Reply With Quote
Thread Tools
Display Modes
